FS/FT Buff.NY 1990 Teg w B16 swap and mods
To many projects not enough time .
1990 Integra Gs 2 door 130k on body . Just inspected Body White interior is Black .no rust Texas car 2 years in Buffalo. Needs paint. and tuning
Jdm B16 with jdm pwo vtec ecu. 10k on the swap.
New with swap:Oil pump, water pump, distributer, oil pan gasket, timing belt ,tie rods,lower ball joints, both half shafts,fuel filter, cap and rotor,lightned crank pulley, and an after market aluminum radiator.
2 1/2 inch exhuast with high flow cat and apex muffler w/3in outlet
Tranny is original B18 with stag 3 clutch ( not great for the street ,but it will never slip )and a short throw shifter .
New rear brakes needs fronts soon
Interior is stock except 3 inch tack mounted on dash
pass side auto seat belt isn't functioning correctly and the power sunroof motor is burned out but I have a complete sunroof that does work to replace it .
Extras
Comes with a set of front koni blues and neuspeed race springs 2 inch drop. And a full set of guages with white face and adjustable indaglo . Both used but in good condition .
$3500 I may consider trades with cash for those of you with moms old car if its new/nice for my girl friend . Her Contour is on its last leg . I'll try to get some picture this weekend or you can come check it out .
Extras
