itr cam gains in gsr?
i searched but couldnt quite find exactly what i was looking for so i figure its worth a shot to ask someone with first hand knowledge. i am going to be putting my new itr cams in with omni valvesprings and retainers. i have talked to a few people about the hp. gains i can expect but ive gotten really broad answers. i have heard from 2 to 5hp all the way to 15. does anyone here have any first hand knowledge (dyno, 1/4 times ect..) as to what i should be looking to gain? i didnt pay for the cams either just traded my old nitrous setup for them so i think its worth it no matter what since i HATED nitrous
It will definitely pull hard all the way to 8,000 rpm, and will especially help in the higher rpms. VTEC will also kick harder. I picked up 2 tenths with the cams on the 1/4 mile. Most people will tell you that you'll see better gains with the CTR cams, which is true, but these are still a great upgrade.
Do you need to change anything else when doing that swamp? Dyno? ecu? And what about the 2 butterfly of the GSR? Cause I know ITR has a single stage over a 2 stage design intake manifilod?
Or you just throw the ITR there and that it? Tell me everything please!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninor »</TD></TR><TR><TD CLASS="quote">do not forget that gsr valvetrain on the exh side is single spring. I would not run ANYTHING but gsr cams on that. On the intake you are fine, I had type R cam for years...</TD></TR></TABLE>
that single spring wont hold up?
It might hold up....it's recommended that you upgrade to dual exhaust springs though. Especially if you plan on raising your rev limiter in the future. On an expensive engine, like the gsr, I would not take the risk of something that MIGHT hold up.
Also, I believe that the 98+ Jdm ITR ran the CTR cam. The difference between the two I can tell you is great. I have the 97 ITR and a friend has the 98, his crossover is a lot more aggressive than mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxogsr »</TD></TR><TR><TD CLASS="quote">Do you need to change anything else when doing that swamp? Dyno? ecu? And what about the 2 butterfly of the GSR? Cause I know ITR has a single stage over a 2 stage design intake manifilod?
Or you just throw the ITR there and that it? Tell me everything please!</TD></TR></TABLE>
Somebody can teach me about that swamp what exactly I got to do to do it properly??
where are the gains in the exhaust cam or the intake one? would the gains be noticable or worth it just to put in the intake cam and leave the gsr exhuast one? if we are only talking 1 or 2 hp i may as well just leave it out so i dont have to get new valvesprings/retainers if i really dont need to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlepT ej6 »</TD></TR><TR><TD CLASS="quote">Would cam gears be a good idea to mate them with the ctr/gsr cam combo?</TD></TR></TABLE>
if you plan to dyno tune. i have the itr intake cam in my db8. great cams for the buck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon »</TD></TR><TR><TD CLASS="quote">what about fuel mapping? what obd1 ecu program would be best to run?</TD></TR></TABLE>
Yes, what map or VAFC settings should be used on a GSR with 00+ or CTR cams?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trustbuddy »</TD></TR><TR><TD CLASS="quote">
if you plan to dyno tune. i have the itr intake cam in my db8. great cams for the buck.</TD></TR></TABLE>
would putting both in make that much of a diffrence? like if you just have the intake cam is that the cam thats making the hp or is it mostly the exhuast one?
you can run both intake and exhaust on gsr valve springs as long as you dont raise your rev limiter. i know because i did it on my 130,000 mile gsr motor. ctr cams alone dropped my 1/8 mi. times from 9.39 to 9.15 and then i put in cam gears and set them to +4, -2 and put in a lightweight flywheel and dropped my time from 9.15 to 9.01. never dynoed it.
