je pistons or usdm integra type r pistons
Old Mar 30, 2005 | 12:15 PM
GsrSleeper18's Avatar
Default je pistons or usdm integra type r pistons
got a 95 b18c1 and i'm debating in getting pistons but i don't know if je pistons are better than type r pistons or if theres no difference and if type r pistons then will the fit in a gsr block?
Old Mar 30, 2005 | 12:46 PM
.Eddie's Avatar
Default Re: je pistons or usdm integra type r pistons (GsrSleeper18)
WOW, their are a few questions in just one sentance buddy. Well, first off it depends what your plans are for the motor. Are you just doing a rebuild and looking for a slight bump in power/compression. ITR pistons will fit since both blocks share the same bore(81.00-81.50 mm from Honda) You didn't not say if you wanted to use ITR or CTR pistons in your motor, so this answer is going to be incomplete. Again, it depends on what your are building the motor for. The JE pistons would be a nice if you needed to have a lighter piston with a different comression ratio then what is available from Honda. The price is a bit higher for these pistons, and I personally would stay with OEM pistons for a mild rebuild. If you have other questions use the "search" button, it is your friend.
Good luck
~Eddie
Old Mar 30, 2005 | 12:55 PM
Default Re: je pistons or usdm integra type r pistons (killerb20zallmotor)
usdem integra type r pistons...will there be a big difference as far as power goes compared to gsr pistons???
Old Mar 30, 2005 | 12:58 PM
Ketone's Avatar
kinda depends on your set up, and tuning
Old Mar 30, 2005 | 01:02 PM
Default Re: je pistons or usdm integra type r pistons (Ketone)
what do you guys mean...i mean i did i/h/e, piping w/ high flow cat, msd, intake manifold, and fuel pressure reg. your usual basic all motor set up
Old Apr 1, 2005 | 03:55 PM
trustbuddy's Avatar
http://www.c-speedracing.com/h...c.php
if you go here, you can calculate the compression for different motors with different pistons, etc.
i'd say..get jdm itr pistons.
kennie555
Feb 21, 2013 04:32 PM
mplayboy01
Jul 15, 2011 09:49 AM
kingofbattle909
May 3, 2011 07:33 AM
alex6883
Jul 24, 2006 08:32 PM
