Tire pressure...
What p.s.i. you guys running with? Manufacturer suggests 36f, 42r, now my bike shop told me to go 36f, 36r. This is for street riding. The higher the p.s.i the more life you get out of the tire but with a with a lower p.s.i. the tire will conform more to the road.
31/32 track 36 street 38 commuting, some will say 38 seems high, but keep in mind this is for commuting...
I keep the front a couple psi lower than the rear for each setting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backlash »</TD></TR><TR><TD CLASS="quote">I run 33. I usually keep the front the same and change the back, except when at the track.
EDIT: hey that sorta rhymes!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> oh like you can up with something catchier than that.
What tires are you running? The PSI you run at the track depends on the brand. Most people say Pirelli recommends 34/34 for their Diablo Corsa. When I had M1s, I ran 29-32/28-30 at the track.
For commuting, 36/38 should be fine. Spirited riding you can run a bit lower pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egryda »</TD></TR><TR><TD CLASS="quote"> oh like you can up with something catchier than that.
I guess you're right.. if Method Man was spittin that, it'd probably sound dope.. then again, I keep picturing Vanilla Ice with a little bit of Dr Seuss rapping to Torque.
Mine rhymes too.
</TD></TR></TABLE>I guess you're right.. if Method Man was spittin that, it'd probably sound dope.. then again, I keep picturing Vanilla Ice with a little bit of Dr Seuss rapping to Torque.
Mine rhymes too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectF4 »</TD></TR><TR><TD CLASS="quote">how the hell do you ht heads, manage to turn a tire pressure thread, into a rhyme game... that's the kinda sheit that makes this site a shame...
Part of it is called being bored at work. I put up some usefull info before the mad ryhmes came out though LOL
</TD></TR></TABLE>Part of it is called being bored at work. I put up some usefull info before the mad ryhmes came out though LOL
RacerZook
Dec 30, 2004 02:21 PM
