Big garage Sale: Built engine swap, turbo parts ect....
Old Mar 30, 2005 | 08:52 AM
BoM's Avatar
BoM
Default Big garage Sale: Built engine swap, turbo parts ect....
I've given up on this project. Most parts are New unless i say its been used.
Everything has to GO! I accept paypal, (CC add 3%) c1turbo@hotmail.com, MO, Checks and cash for locals. Money talks and i can meet up with you CT -- VA if its a big part. Prices are all SHIPPED i might have to ask for more on shipping if your like in CA or Hawaii ect...I'm Located in South Jersey Blackwood.
i have a complete engine (longblock) + tranny swap
GSR motor and tranny - if someone wants it.
95' P72 Head 0 miles after rebuild - complete with valve cover, no manifolds.
Work done by Greg @GBR-Tuning.com
Portflow inner, ITR outter springs with ENDYN nitrite valves, ARP headstuds
$1200
97' GSR block B18C1 0 miles - So fresh so clean
Resleeved to 84mm (1.9?L..) Darton MIDs sleeves, CP pistons 9:1 comp, Manley Turbo Tuff Rods, New type R oil pump, ACL bearings. I have reciept of the build also for the buyer. i paid $3500 and the block will Handle anything. Asking $3200 shipped
95' GSR tranny - 80k miles no grinds & no problems cause its from my Old integra.
$900
Selling as a swap i give you the p72 ecu, axles, shiftlinkage, motor mounts and wire harness for $6000 shipped or cheaper for Pickup.
-Quaife LSD - For LSD brand new still in box bought from the Laskeys. $850
-Drag Polished IC piping with HKS racing Type II bov
for integra gsr - fits eg gsr hybrids too. $500
-SC44 turbo precision 5 bolt .60 a/r t3/t4
-3inch downpipe 5 bolt no ending flange, for mounting with compressor facing drivers side & comes with gsr o2 sensor 4wire $150
-Thermal Catback with 3inch Flex eliminating cat used 1000 miles soo clean! 4 92-95 Civic hatch - $450 shipped.
-Hondata S200 w/ boost and 3step, no datalog thats it. still in box and plastic - $400
-Greddy Gauges - White faced 60mm Boost mechanical for $85
60mm EGT peak/warn memory with probe for $160 Together $230
both are new, but no box.
-Drive brake MC brace polished - $60
-Aeromotive FPR with SS -6an feed and return lines from fast-turbo- $200
-NGK blue ignition wires new - SOLD
-NGK sparkplugs 2 sets BCPR7ES-11 $22
-Pair of AXE Racing seats adjustable recline and Harness holes comes with sliders - $350
-Denji Projector headlamps with some bulbs in em. looks blue- $50
-JG victor X manifold cast - new fittings already installed - $290
-RPM Services 70mm TB with throttle cable bracket from gsr - $250
-Tial Wastegate 40mm purple top 8psi spring inside also including dumptube flange with a dumptube - $350
-Clutchmasters stage 4 clutch (4puck sprung hub) New complete - $325
-ACT Flywheel streetlight $250 together $525
-PWR intercooler 22x8x3 with welded on brackets (L)just cut the underside of your bumper support and it fits perfectly flush under the bumper support and just drill two holes for the bolts. $400
-PWR single side radiator with slim 10" fan with harness for civic - SOLD
-2 resistor packs for injectors $20each
I got alot more but still gotta upload pix and stuff. i just wanna clear this stuff first. Email for pictures im pretty quick at replying.
THANKS.
Huy Tran (609)-280-1458
Bom
Modified by BoM at 12:20 PM 4/6/2005
Old Mar 30, 2005 | 05:59 PM
BoM's Avatar
BoM
Default Re: Big garage Sale: Built engine swap, turbo parts ect.... (BoM)
Bump up for OFFERS.
Old Mar 31, 2005 | 07:39 AM
BoM's Avatar
BoM
email for pictures.
Old Apr 2, 2005 | 06:40 AM
hydroflip's Avatar
bump
Old Apr 14, 2005 | 09:00 AM
hydroflip's Avatar
Default Re: Big garage Sale: Built engine swap, turbo parts ect.... (hydroflip)
up
2point0VTEC
Mar 8, 2016 01:49 PM
atlitomontoya
May 13, 2012 06:03 PM
LIFER
Nov 7, 2005 08:59 AM
BoM
May 1, 2005 06:26 PM
