CTR throttle body
Old Mar 30, 2005 | 07:48 AM
93gsrcoupe's Avatar
Default CTR throttle body
Three questions: 1) Will a CTR throttle body bolt onto a gsr skunk2 intake manifold? 2) Is the bore the same as the ITR? 3) Can I use my GSR map sensor with it?
Old Mar 30, 2005 | 08:10 AM
Jasper_db1's Avatar
Default Re: CTR throttle body (93gsrcoupe)
If the S2000 throttle body works...
Old Mar 30, 2005 | 10:27 AM
Terrible One's Avatar
yea it should bolt up, FYI d-series and b-series throttle bodies are all interchangable. ctr and itr throttle bodies both share the same bore of 62mm. and i think that map sensor will work also. please note that the skunk2 IM throttle body inlet is 60mm (not sure)
EMO-anthony
May 6, 2004 04:12 PM
EGkTiOn_CiViC
14
Nov 22, 2002 05:59 AM
