OBd0-to-OBD1 conversion harness groupbuy......
Ok guys.....7 + buyers = 100 shipped and 12+ buyers = 85 shipped.
OBD0-to-OBD1 conversion harnesses. Convert your OBD0 car to run the newer 92-95 Ecus. You will need OBD1 ecu, OBD1 or OBD2 distributor, OBD1 injectors(Optional), 4 wire O2 sensor. This harness is great for those going mini-me or wanting to run a D16z6 swap in their EF. Comes with detailed instructions for install and use. This is a intermediate harness that plugs into your stock in-cabin harness. Then you plug the OBD1 ecu into the other side. If you have a HF or Si, then all you do is plug this harness in, then run the appropriate wires to the appropriate sensors. This group buy will expire on February 15th. I accept money orders or cashiers checks. I have a million references if needed. Located in Northern california.
UPDATE: IF you do not have or want to bother with the OBD1 injectors, you dont have to. You can keep your OBD0 injectors, as long as you keep the resistor box. I know that alot of people are having a difficult time gathering OBD1 injectors so this a the solution to that problem.
[Modified by Blown90hatcH, 4:38 PM 2/5/2002]
if you already have a 1st gen motor, don't bother, to with OBDI electronics or a harness but if you swap in a 92+ motor then its a different story
my friend has a 89 si hatch, and just ghetto rigged all wires with no harnesses. AN
H22 motor OBD - I
this harness would make it plug and play right? need to fix the mess....its throwing codes.
[Modified by BoM, 6:13 PM 1/27/2002]
H22 motor OBD - I
<U>If you are in....You must email me and say "I am in"! You have to email me by the dealine to be counted!</U>
[Modified by Blown90hatcH, 6:09 PM 1/27/2002]
Modified by Blown90hatcH at 11:13 PM 3/30/2008
See if you can tell me if this will work, running an '88 CRX Si with a B20 VTEC using your harness and running the P28 so I don't have to worry about the knock sensor and then taking out the injector resistor box or at least disconnect it. I already have a set of bod-1 injector pig tails so that's good. Am I thinking right on this? Can you tell me why the different distributor is needed to be used for obd-1?
This may be a stupid question but does this work on DX's? You will still have to wire for the injectors though, correct?
Jason
4g uses a injector resistor box and 5g doesn't, right? If this is the case, do I still use a resistor box and wire up the car as if I wasn't using the harness and then go from there? When is the deadline for this buy?
Vsual got the deadline for you. On the resistor box, you will just wire all 5 wires together and remove the resistor box all togather.
JAson
JAson
Hey Jason, I'm interested. Let me know when you get it down to 75 bucks!
Jeff-
Jeff-
...so I don't have to worry about the knock sensor...
If you wanted to install an OBD1 94-95 LS motor in your EF 88-91 civic....then yes this is what you will need. It must be converted to multipoint fuel injection if it isnt already.
Jason
Jason
