pot holes and damage
what kind of damage, can appot hole "really"
ps i hit one and now my car makes theses sounds!
about this size-->https://honda-tech.com/zerothread?id=1030434
i'm in your same position. i hit this 2 huge pot holes that were connected. i was going at least 30+ mph and scared the **** out me. now i heard this clinging sound everytime i run over a bump, even those lane dividers.
my "main" sound comes from the passnerger side, my mudder flaps( the plastic that goes over the 2 front tires, got half way ripped off, i fixed em, thanks to ZIP TIES! oh yeah i was going about 30 or less.... i looked under car, everthing looks fine! oil pain
I have 16” rims that are cast aluminum and my tires are VERY thin, 205/40/16. the sidewall is very small, and the tire was the wrong size. Because of this, the air pressure must be VERY high, like 38psi so that the rim doesn’t get damaged. I was running at 33psi and that wasn’t enough. I hit a hard pothole and my 2 right rims are now out of round, meaning there slightly bent so they aren’t 100% balanced. Its noticeable on the highway at 85mpg, a light vibration. I may replace those rims and get a 205/50 profile, which is slightly taller than stock, but better than shorter.
importdude2000
Nov 1, 2004 09:42 PM
