Need D15B7 Replacement, #4 Cyl is @ 15psi Compression.
Old Mar 29, 2005 | 07:14 PM
HonDad's Avatar
Default Need D15B7 Replacement, #4 Cyl is @ 15psi Compression.
My 94 Del-Sol needs a heart transplant with only 182K on the Odometer!
Compression is: #1=175psi, #2=150psi, #3=150psi, but #4=15psi
Spark Plugs 1 through 3 all looked good, frosted white to yellow at gap.
Engine was using 1 quart of oil every 600 miles (Blue Smoke above 4K RPM)
Any Suggestions or Advice on the following: Junkyard Engine compared to JDM replacement (Claiming ~40K miles)? Can you believe the JDM mileage advertisments? Rebuild (in-place) Vs. Swap? Swap upgrade (1.5 SOHC to 1.6 DOHC/VTEC) costs?
Thanks For Any HELP!!
young geezer
May 12, 2010 09:26 PM
gunsnbam
12
Mar 28, 2010 07:51 PM
95greenlude
Nov 3, 2007 04:21 PM
square_1
Sep 15, 2006 02:08 PM
Krut
Feb 9, 2005 06:12 AM
