H4 bulbs, aka Si-R front end
Old Jan 26, 2002 | 05:00 PM
E-AT_me's Avatar
Default H4 bulbs, aka Si-R front end
the bulbs on you guys' Si-R front end, you use H4's? if so, how is the wiring different? different plug? thanks..
Old Jan 26, 2002 | 08:03 PM
Denny317's Avatar
Default Re: H4 bulbs, aka Si-R front end (Rexman)
Yes. SiR and ZC headlights both use H4s. Uses one bulb instead of two I believe.
Old Jan 26, 2002 | 09:49 PM
marty's Avatar
Default Re: H4 bulbs, aka Si-R front end (Denny317)
Negative.. H4 bulbs will not fit without modifying the bulb. You use the same bulb as the SiR, ZC, and DA6 which is the H4C or H4H bulb. You can purchase these bulbs from jspec.com. Warning.. they arent cheap !!!
Old Jan 28, 2002 | 04:05 PM
Denny317's Avatar
Default Re: H4 bulbs, aka Si-R front end (MugenEF7)
Cool. Thanks for clearing that up for me.
Ldo
Sep 24, 2008 11:58 AM
MisterB
Jan 25, 2003 07:03 PM
Spaceballsthelunchbox
Dec 27, 2002 09:01 PM
f0de
Oct 3, 2002 10:25 AM
E-lude78
Aug 17, 2002 01:59 PM
