cam seal?
Old Mar 29, 2005 | 05:11 PM
skunk2eg's Avatar
Default cam seal?
on the front of the motor on a b18b i need to replace the seal on the front left side (right above the ditributor). Is it an easy fix? is all i have to do is take off the valve cover and undo the bolts, or do i have to actually mess with anything else? it has recently started to leak oil down the front of the block.
thanks in advance
Old Mar 30, 2005 | 08:22 AM
1hOt95GsR's Avatar
Default Re: cam seal? (skunk2eg)
Don't know if you've found your answer yet but here you go anyway:
http://student.ucr.edu/~ohe02/ ---> Go to DIY on the left and then click Cam Seal Replacement.
Here's another one:
http://www.team-integra.net/se...D=576
Hope this helps but next time search first.
Old Mar 30, 2005 | 08:26 AM
AlxSiR7's Avatar
it's pretty simple.. heres a good site with a how-to
**ha, just saw 1hotgsr already gave you this link
Old Mar 30, 2005 | 09:32 AM
mr.beeks's Avatar
Default Re: cam seal? (AlxSiR7)
best advise is not to overtighten the bolts caus they break off easy......
Old Mar 30, 2005 | 11:11 AM
rastj2's Avatar
replacing it is easy, the bolts though are torqued pretty tight there in my exp.
Old Mar 30, 2005 | 11:13 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (rastj2)
Technically, it's a cam plug... The cam seals (2 of them) are on the opposite end.
Old Mar 30, 2005 | 01:16 PM
AlxSiR7's Avatar
i wouldnt go past 8lbs for the valve cover bolts.. i ended up breaking the cam "plug" bolts and had to buy new ones and grind them down to the proper length. what a bitch! here my thread about my experience with the cam seal leak.. i got pix in there
https://honda-tech.com/zero...age=1
nicko360
Jan 14, 2007 01:16 AM
95hatchfire
Oct 28, 2004 07:35 PM
94ls
Feb 3, 2004 12:52 PM
Integra_Boi
Jun 18, 2003 12:11 AM
JLange
Apr 4, 2003 07:16 AM
