1991 Accord Trunk Leak again
I know it has been posted before but I have tried almost everything to stop my trunk leak. I fixed the sunroof drain hose(it had pulled out of the fender and was soaking the trunk), put new tailight gaskets in, siliconed my spoiler bolts/holes, checked and caulked around the trunklid weatherstripping and fixed the antenna leak. Now I am still having water issues; not as bad but still bad enough to fix. I saw a post before about the rear window trim leaking where the clips go thru the body into the trunk. Any opinions or ideas before my sub, etc gets ruin
ed. Thanks for any help!!
check this thread out it will probably be of some help, as it has the window trim portion you were referring to.
It shows up after a heavy rain on both sides of the trunk. I am in the process of re-sealing the holes for the window trim and will re-assemble it and see what happens. Got to get new clips since they break so easily when removing them. We are expecting another heavy rain by weeks end so I will soon find out. Thanks for the link and replies!!!!
