individual throttle bodies
Old Mar 29, 2005 | 04:10 PM
1itr's Avatar
Default individual throttle bodies
I was thinking of purchasing toda's itb system. just wondering if any one was familiar with this. what are the pros and cons?
Old Mar 29, 2005 | 04:42 PM
Mythias's Avatar
Default Re: individual throttle bodies (1itr)
"Your search for 'toda itb' returned 26 results."
Guess ya didnt try to search, did ya? BTW, do you even own an ITR?
Old Mar 29, 2005 | 05:48 PM
1itr's Avatar
Default Re: individual throttle bodies (mythias)
easy im new and yes i own an itr.
Old Mar 29, 2005 | 07:09 PM
Black R's Avatar
25 Year Member
pro's: improved throttle response; more power throughout the entire rpm range
con's: cost; accoutrements needed to run them effectively; lots of tuning needed.
http://www.todaracing.com
http://www.todaracing.com/prod....html
http://www.todaracing.com/itbfaq.htm
Old Mar 29, 2005 | 07:17 PM
Kendall's Avatar
When considering ITB's, consider the exact design you're looking at. Toda places the injectors behind the throttle plates, which is excellent for a road racing application that doesn't idle much as a bunch of fuel ends up getting sprayed all over the firewall. This design improves fuel atomization and has been proven to make excellent power.
Other ITB manufacturers place the injectors in front of the throttle plates which, though still excellent in road racing applications, is much more universal and won't dirty up your engine bay if the setup is going in a daily driver. There's a bit less fuel atomization, but usually not enough to have any drastic effect in performance. Jenvey ITB's rely on increased air velocity to help atomize the fuel.
Old Mar 30, 2005 | 05:03 AM
1itr's Avatar
Default Re: (Kendall)
thanx
Old Mar 30, 2005 | 05:16 AM
Bradstard's Avatar
Tuning is the key. You should also look at some TWM's. I heard this last weekend that the Toda ITB's were discontinued and there were only two sets left. I am also looking in to go ITB's.
Old Mar 30, 2005 | 07:10 AM
ITRacer121's Avatar
I would also do ALOT of searching in the all motor forum
alot of those guys are running some of the home made stuff and having good results
Old Mar 30, 2005 | 07:56 AM
AnToNy's Avatar
Alot of cars use TWM's, and there are several people that have made their own setup from a motorcycle throttle body. You need to do alot of research on this topic.
ken-e
Jul 26, 2010 07:55 AM
SOLOITR2001
May 7, 2007 05:17 PM
Hatchorama
May 31, 2005 11:19 AM
1stealthls
Dec 13, 2002 09:51 PM
Asild
Mar 5, 2002 02:31 PM
