A few picture questions specific to the engine I own, numbered too!
QUESTION ONE:
Recently I've seen some posts of "gunky" engines sold to people. To my untrained eye, mine looks pristine. Understand that I'm not going to tear the whole engine down, especially since it looks fine up top (to me).
http://www.we-todd-did-racing....D.jpg
QUESTION TWO:
See that black box in the lower right to the left of the thermostat housing? Is that the stock PCV catchcan? Does something from the Z6 plug into this (SIRII)? Isn't she nice and clean?
QUESTION THREE:
This came with the engine, junk it? Isn't the one I have in the car adequate?
QUESTION FOUR:
This sure doesn't look stock, the ECU has a new chip with a wire hanging out, the chip says "Rivertec". So the settings won't be stock? Can I re-use the Z6 ECU as it?
QUESTION FIVE:
This guy looks nubbed off, what do I call it? Some kind of torque mount? Needs replacing I take it. What would a Honda dealer call it?
QUESTION SIX:
This is coming from the power steering pump (I want to keep it for now). Is there an equivalent to the crimped fitting in my harness already? Plug and play?
QUESTION SEVEN:
You can't really tell in the pics but on one of the axles the boot seems a little bound up on the inside, total loss?
QUESTION EIGHT:
WTF?
Thanks!
QUESTION TWO:
QUESTION THREE:
QUESTION FOUR:
QUESTION FIVE:
QUESTION SIX:
QUESTION SEVEN:
QUESTION EIGHT:
WTF?
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptivaBlue »</TD></TR><TR><TD CLASS="quote">QUESTION THREE:
This came with the engine, junk it? Isn't the one I have in the car adequate? </TD></TR></TABLE>
Yes you can junk it or try to sell it maybe...its suprising what people will buy trust me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptivaBlue »</TD></TR><TR><TD CLASS="quote">QUESTION FIVE:
http://www.we-todd-did-racing....D.jpg </TD></TR></TABLE>
Umm...i got mine at like autozone...cost like $46 bucks for one of those. They are the front lower engine mounts.
[QUOTE=CaptivaBlue]QUESTION SEVEN:
When in doubt replace them....They arent that expensive and if you are trying to do it right do it right the first time...thats what i've learned in my experience.
Hope some of that helped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 »</TD></TR><TR><TD CLASS="quote">
Keep the fuses...they cost a grip if you ever blow one...I'd try to sell the fuse box first, then strip the fuses out of it, the chunk the box
Yep, she's in my closet!
I have a manual currently so I'll crawl under and check the tranny torque mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillBot »</TD></TR><TR><TD CLASS="quote">#8
............An engine sling?
hahahahahhahah</TD></TR></TABLE>
What about ECU and the wire hanging out of her?
What about ECU and the wire hanging out of her?</TD></TR></TABLE>
Looks like someone chipped it...get a better pic of the guts and I can tell if its a decent job or crap. Looks like a p28. Check the sticker on the side, too.
Here's all the pics of my ECU.
Will I need to get a new ECU? I want the thing to just run on a stock map, God only knows what the prior person programmed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptivaBlue »</TD></TR><TR><TD CLASS="quote">QUESTION ONE:
Could've changed the oil more frequently
QUESTION TWO:
Again oil changes. And yes thats what the pcv connects to, the oil catches and is put back into the block.
QUESTION THREE:
The one in your car is fine
QUESTION FOUR:
No fu!@ing clue, not a computer guy
QUESTION FIVE:
Supplementary trans mount, passenger side supplementary mount
QUESTION SIX:
Dont know, my past swaps I never put power steering back in
QUESTION SEVEN:
You wont know until you put them in, if you have some extra cash go get some refurbs if not put them in and see, it takes like 10 minutes to change axles
QUESTION EIGHT:
WTF?
your a wierd dude.................
Thanks! </TD></TR></TABLE>
QUESTION TWO:
QUESTION THREE:
QUESTION FOUR:
QUESTION FIVE:
QUESTION SIX:
QUESTION SEVEN:
QUESTION EIGHT:
WTF?
HCJDM1
Feb 1, 2007 09:02 PM
