where is the main relay for the 97 civic??
you idiots stop giving incorrect information.. your main relay is behind your glove box, above your ecu in the corner to the right... you will need to take your glove box out and it will be it the right hand side corner..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLCivic »</TD></TR><TR><TD CLASS="quote">thanks, i haven't tried there, everyone keeps telling me under the dash</TD></TR></TABLE>
the best way to find it since its hidden kinda is to take the glove box off and take the passenger side kick panel off (where you ecu is) and then it will be above your ecu and to the extreme right of the glove box.. very tight spot.. but thats where it is.. the other guys were giving you the location of the main relay for the 92-95 civics (located by the hood release cable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">
the best way to find it since its hidden kinda is to take the glove box off and take the passenger side kick panel off (where you ecu is) and then it will be above your ecu and to the extreme right of the glove box.. very tight spot.. but thats where it is.. the other guys were giving you the location of the main relay for the 92-95 civics (located by the hood release cable)</TD></TR></TABLE>
sweet had the same issue...i was looking at the driver side, will take a look there this weekend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">you idiots stop giving incorrect information.. your main relay is behind your glove box, above your ecu in the corner to the right... you will need to take your glove box out and it will be it the right hand side corner..</TD></TR></TABLE>
absolutely correct!!!!!!
to get to mine I dropped the glove box and BAM! it was right there.
Jerzey Rex
May 4, 2006 10:47 AM
Orangecivic251
Jun 9, 2004 10:30 PM
