leaking fuel filter
i just put in a new fuel filter and it leaks.. then i put the old one on and no more leaks. so is this new filter bad? i already threw it away but if there's a solution i will go pick it up in the garbage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">did you put new washers on?
where is it exactly leaking?</TD></TR></TABLE>
I would have to say its probably the washers. The new filter should have come with 2 new washers, they go in-between the banjo fitting and the filter inlet and outlet.
From: I told you to wait in the truck in Texas, United States
I have seen after-market filters come with some really "cheezy" washers..
Get some new ones from Honda..
They are usually thicker and fit the connections more tightly..
I have re-used the stock ones before even though
the instructions say not to..
i went to honda and each wash cost 4 bucks each... 5 washers thats 25 bucks.. so i said forget it. i asked him how much was the fuel filter he said and i quote "it's 25 bucks plus it includes all the washers".. wtf lol
flanker
Jan 19, 2019 07:30 PM
