Porting b18a head(pics and ?'s)
Old Mar 29, 2005 | 01:24 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Porting b18a head(pics and ?'s)
Well i started porting my spare LS head this weekend. It took 4 days to get 1 port partially done(2 days were spent practicing on an old single cam head). Im not really taking off that much metal...im really just getting rid of all the casting flaws. I have enlarged the bowl area a little and im gonna make the port exit a little bigger. Nothing crazy. I also kinfe edged the seperator. Heres some pics of what i have done so far. I have a little more work on that one port but its basically done(gonna smooth it out a little more).
Dremel tool is your friend
Bowl area(bad pic but you get the idea)
A little more smoothing to be done and shell be ready to go
Bling Blang!
Now for my questions. Ive nicked the valve guide a few times so i thought i might just shave it down a little for better flow. Will this hurt anything? I just dont wanna weaken the guide. Now for my next question...i know that you want to leave the intake ports a little rough to get better fuel atomization...but exactly how rough should you leave it? What grit would be good for the final grind to get the texture that you want? Thanks in advance
PS-any tips or opinions would be greatly appreciated...especially if you know of a certain area that needs more attention than others(such as the bowl area, mouth, seperator).
Old Mar 29, 2005 | 02:23 PM
hybrid_vtec's Avatar
Default Re: Porting b18a head(pics and ?'s) (sCeRaXn)
Kind of curious. I though of doing my own porting on my extra head laying around!
I do know that you have to be careful on the exhaust side! You do not want to change he angle of the ports. If you look at the exhaust port you can tell one side is flowing to the port at an angle unlike the other which is flowing straight ahead.
I also heard that you want to be careful on the exhaust ports or you will ruin the head. There is a water line/jacket for the coolant under those ports! I only heard that so take it with a grain of salt until others respond to my comments>
Old Mar 29, 2005 | 02:51 PM
ExospeedAMcrx's Avatar
I wish there were more LS fans out there. There's like 5 on this board and 2 of them are you two. hehe.
Old Mar 29, 2005 | 03:17 PM
B16aDasher's Avatar
Default Re: Porting b18a head(pics and ?'s) (exospeedAMcrx)
yeah, b16a here Nice work, takes alot of ***** to do it myself.
Old Mar 29, 2005 | 04:06 PM
Grand's Avatar
looks good but if thats the intake side your smoothing it out to much it needs to be rough to atomize fuel properly if not you have problems with fuel puddling inside the intake ports of the head
but good gob man keep us posted did you flow test if before ?
id like to see a before after cfm test of an amatuer port job
Old Mar 29, 2005 | 04:08 PM
hybridpatient95's Avatar
non vtec all the way!! im thinking of doing my ls head.. any tips?
Old Mar 29, 2005 | 04:14 PM
Grand's Avatar
Default Re: (frankenfiend 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 &raquo;</TD></TR><TR><TD CLASS="quote">non vtec all the way!! im thinking of doing my ls head.. any tips?
ive done a few with flow bench results im me i can give ya some tips but im still an ammy to i have my heads done by pros lol
Old Mar 29, 2005 | 04:50 PM
athoughts's Avatar
Default Re: (LG_R32)
hey what tip do you have on the dremel?
Cause when i did my manifold i just had the sander/grinder, and then some wack brush that polished it
Old Mar 29, 2005 | 06:21 PM
sCeRaXn's Avatar
Default Re: (athoughts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">I do know that you have to be careful on the exhaust side! You do not want to change he angle of the ports.</TD></TR></TABLE>
Luckily i noticed that before i started. When knife-edging the seperator i was careful not to take off too much from the right side of the port. It just seems like angling it in more would cause more turbulence in the port.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">I wish there were more LS fans out there. There's like 5 on this board and 2 of them are you two. hehe.</TD></TR></TABLE>
Thats why ive always loved dealing with you guys. It seems like yall really know the potential of the LS and actually carry products for it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 &raquo;</TD></TR><TR><TD CLASS="quote">looks good but if thats the intake side your smoothing it out to much it needs to be rough to atomize fuel properly if not you have problems with fuel puddling inside the intake ports of the head
Nah thats the exhaust side...you can tell because there isnt an injector hump at the top of the port. And unfortunately i couldnt get it on a flowbench. If i had that kinda money i woulda just paid a pro to do it all for me
Its gonna take a while to get it all done...but this is my first time and i want to make sure its done correctly. Im just taking my time and learning as i go. And im making sure not to rush or skip any process. Ive done ALOT of research on porting in the past 2 weeks. But ive only found articles about porting and polishing in general. I learned a great deal but i wanted some input from people that have actually done an LS head. Because each head has certain areas that need more attention than others.
Keep the questions and comments coming. Im excited about this project. After this i can say that ive pretty much done it all
Old Mar 29, 2005 | 10:40 PM
athoughts's Avatar
Default Re: (sCeRaXn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">hey what tip do you have on the dremel?
Cause when i did my manifold i just had the sander/grinder, and then some wack brush that polished it </TD></TR></TABLE>
Old Mar 30, 2005 | 07:22 AM
arw321's Avatar
Don't forget about me.
My head porter cut my valve guides right down. No problems at all.
Old Mar 30, 2005 | 09:35 AM
drewzilla's Avatar
ahhhh the "stoned performance" head.
Old Mar 30, 2005 | 12:43 PM
sCeRaXn's Avatar
Default Re: Porting b18a head(pics and ?'s) (drewsrt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewsrt &raquo;</TD></TR><TR><TD CLASS="quote">ahhhh the "stoned performance" head. </TD></TR></TABLE>
HAHAHAHA...cant beat the quality of "stoned performance's" work
I dont really have any tips because i just started myself. I use 4 different sanding drums, 3 different stones, and an abrasive wheel. Im just taking a little off at a time starting with 120grit(i think) and ending with the abrasive wheel then 600 grit. Just take your time and dont cut any corners...thats all the advice i have because thats all i know right now. Im sure ill have more in a few weeks
Old Mar 30, 2005 | 03:07 PM
Grand's Avatar
it looks good man ive done ls heads the separoator is the weak link in an ls head imo and my head porters opinion we have seen the best flow gains from knife edging and thinning it out as well as making sure its still rough on the intake side
good luck
Old Mar 30, 2005 | 06:40 PM
projectTeG's Avatar
&lt;&lt;&lt;&lt;Another ls'er in the making right here!!!!, im thinking about picking up another ls to prctice p&p on
Old Mar 30, 2005 | 10:31 PM
f22btwincam's Avatar
Default Re: (projectTeG)
hey i am another ls fan lol sup will call me about the cams if i can pick em up,
the porting looks good im too scared to do that if i had an extra head
Old Mar 31, 2005 | 10:13 AM
sCeRaXn's Avatar
Default Re: (f22btwincam)
Well i havent really worked on it too much this week because ive felt like ****...but im gonna go out there and mess with it tonight. That high pitched grinding noise just drills into your head when you already have a migraine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22btwincam &raquo;</TD></TR><TR><TD CLASS="quote">hey i am another ls fan lol sup will call me about the cams if i can pick em up,
the porting looks good im too scared to do that if i had an extra head</TD></TR></TABLE>
It really isnt that hard...just time consuming if its done correctly. All you need is a steady hand and ALOT of patience. It would also help to do alot of research like i did...i learned alot of general info about porting that really comes in handy. I wouldnt recommend doing a crazy port job for your first time, but something as mild as what im doing shouldnt be that bad at all.
Old Mar 31, 2005 | 11:11 AM
Grand's Avatar
if there are any ls fans you should join up with nonvtec.com its a great site and lots of good guys and help
Old Mar 31, 2005 | 12:59 PM
dohcter g's Avatar
Who needs VTEC....he,he,he!!!!!
Old Mar 31, 2005 | 03:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcter g &raquo;</TD></TR><TR><TD CLASS="quote">
Who needs VTEC....he,he,he!!!!! </TD></TR></TABLE>
What is going on with your new build. Progress??? Dynos????
Drop me an email if you dont mind. hybrid_vtec@sbcglobal.net
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 &raquo;</TD></TR><TR><TD CLASS="quote">if there are any ls fans you should join up with nonvtec.com its a great site and lots of good guys and help </TD></TR></TABLE>
Old Mar 31, 2005 | 04:52 PM
LShatchie's Avatar
Im a LS fan! yeah I would be kinda nervous using a dremel, sometimes they just want to go everywhere and sometimes you grind things you dont want to ..
Old Mar 31, 2005 | 04:55 PM
projectTeG's Avatar
Default Re: Porting b18a head(pics and ?'s) (civichatch6989)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichatch6989 &raquo;</TD></TR><TR><TD CLASS="quote">
Im a LS fan! yeah I would be kinda nervous using a dremel, sometimes they just want to go everywhere and sometimes you grind things you dont want to .. </TD></TR></TABLE>
lol....like fingers, i got owned by one a few years ago , nice to see some ls lovers, and goodluck with teh builds
Old Mar 31, 2005 | 06:21 PM
if you are an LS lover, seriously check out http://www.nonvtec.com
This is a website and forum for us guys who choose the path less taken. There are forums setup for B-series, D-series and H-series nonvtecs to go.
Old Apr 1, 2005 | 12:05 AM
drewzilla's Avatar
Default Re: Porting b18a head(pics and ?'s) (dohcter g)
Damn man those are some nice times for your all motor LS eg coupe.
Old Apr 1, 2005 | 12:09 AM
drewzilla's Avatar
Oh yea Ill be taking my camera back over to Seans place this weekend to take more pics if he wants so be on the look out. He's taking his time (which he should) and I help a little when he wants to take a break but DAMN it's time consuming. We'll be done in...probably about a month lol. Regardless it's gonna be worth it and what's really the **** is when you can tell someone you did your own headwork
