got in wreak, questions on replacing suspension, LCA, UCA, etc.... >>
Old Mar 29, 2005 | 11:03 AM
platinum00's Avatar
Default got in wreak, questions on replacing suspension, LCA, UCA, etc.... >>
ok i got in wreak, jumped 3 curbs at 110+
anyway..
i need to replace everything on my suspension..
i have a 2000 ex coupe.
im going with the omni power 12k /10k with rear LCA's setup..
im just going to do a rear disk conversion since the drums and everything are messed up..
what else on the rear suspension would i need to replace if doing the rear disk conversion.
also what needs replaced in the front. is it just UCA and LCA...
thanks for you help.
Old Mar 29, 2005 | 12:21 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: got in wreak, questions on replacing suspension, LCA, UCA, etc.... >> (platinum00)
have you checked your sub frames also? That speed into curbs will prob damage more then ur suspension.
Old Mar 29, 2005 | 12:25 PM
platinum00's Avatar
Default Re: got in wreak, questions on replacing suspension, LCA, UCA, etc.... >> (walker111)
according to the body shop it is fine..
im having them replace the rear corner panel cause i hit a tree.
they wanted like 6k to fix the suspension, 1 front fender, and the corner panel, and paint.
i told them to fix the corner panel for 1300, and i would do the rest of th work..
but besides that im good to go..
Old Mar 29, 2005 | 12:27 PM
pdiggitydogg's Avatar
Jesus 110+?? What are curbs doing on a track?
Id be more concerned about the subframe than just a rear disc conversion.
All the rear disc stuff has been posted...trailing arms, cables off a well matched car, hubs, and an em1 prop valve (thats it). You will probably be replacing the rear u/lca's anyway though (get ones for civic, not integra)
I can practically give you some front uca's off my 97 if you want them. Pay for shipping, a box, and theyre yours.
Old Mar 29, 2005 | 12:28 PM
99SlammedCivic's Avatar
Snipper Snapper
damn homie.. good thing ur ok
Old Mar 29, 2005 | 12:32 PM
platinum00's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Jesus 110+?? What are curbs doing on a track?
I can practically give you some front uca's off my 97 if you want them. Pay for shipping, a box, and theyre yours.</TD></TR></TABLE>
they said the way the one wheel disintegrated, that it looked more like 130
anyway i will take your front UCA if they will fit my 00. im replacing everything to be safe.
i know how to do the rear disk conversion. im just asking if i do that and replace the lower Lcas with the omni ones if that takes care of the whole rear suspension.
how can i check for subframe damage, even though the body shop said it was straight.
Old Mar 29, 2005 | 12:34 PM
platinum00's Avatar
Default Re: (99SlammedCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99SlammedCivic &raquo;</TD></TR><TR><TD CLASS="quote">damn homie.. good thing ur ok </TD></TR></TABLE>
thank you. i know
the guy i was racing totaled his car by bending the frame on his A3 GTI.
oh well **** happens..
being 26 and making 16 yr old decisions is no more.
Old Mar 29, 2005 | 12:36 PM
Just crawl under and look for cracks/bent ****. It'll be obvious for the most part.
Yeah, my uca's will fit. PM me your zip code, I'll estimate costs, and we'll go from there. Youre not far, so it wont take long for them to arrive (not like the car is going anywhere anytime soon).
If youre replacing the rear lca's with omnis, you'll also need to (probably) replace the rear uca's with something too. (Those I dont have anymore). I recommend checking out SPC for that or perhaps omni has something for that too (dont know)
Where the hell were you going 100+??
Old Mar 29, 2005 | 12:39 PM
Snipper Snapper
Default Re: (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">
put in a governer at 80mph
Old Mar 29, 2005 | 12:50 PM
EE_Chris's Avatar
In the front you've got:
UCA
LCA
Knuckle
Tie-rods
Sub-frame
Glad to hear you're alright.
Old Mar 29, 2005 | 01:54 PM
EK k kay's Avatar
Default Re: (EE_Chris)
Damn 110+, 3 curbs and you didn't flip over? Consider yourself very very VERY lucky.
Old Mar 29, 2005 | 02:52 PM
platinum00's Avatar
put in a governer at 80mph </TD></TR></TABLE>
haha,
Old Mar 29, 2005 | 02:54 PM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">In the front you've got:
UCA
LCA
Knuckle
Tie-rods
Sub-frame
Glad to hear you're alright. </TD></TR></TABLE>
what is the knuckle and tie-rod. how much are they.
i guess i can just get my book out, im sure all this is in there.
Old Mar 30, 2005 | 03:31 AM
EE_Chris's Avatar
The knuckle is the piece that connects between the UCA and LCA and has the axle going through it. The brake caliper and rotor are also mounted to this.
The tie-rod is the piece that connects the steering rack to the knuckle.
Prices - San Leandro Honda
Old Mar 30, 2005 | 04:46 AM
platinum00's Avatar
cool, thanks for the info..
im going to rip everything apart and determine what is salvagable. hopefully some parts are still functional
Halo
Honda Fit
15
Mar 8, 2006 11:23 AM
gtturborex
Oct 1, 2005 06:13 PM
SohcVtecCrix
Feb 10, 2003 07:10 AM
