Lip Kit for Del Sol???
ive searched but only found ones that fit 92-95 civics..i know they fit with modification but i want a direct fit....does anybody know a good website that sells front and back lips for a 94 del sol???
Best i can do, the lip fit my car very well... keep in mine its for a civic so its not 100% perfect... But it looks like it could be stock on my car.
And Paint the lip to match! look so much better.
Yall think it looks nice on my car? I DO !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">pic didnt work
works on my computer...
http://image20.webshots.com/20...h.jpg
</TD></TR></TABLE>works on my computer...
Forbidden
You don't have permission to access /20/6/20/60/210762060jMucry_ph.jpg on this server.
guess you have to be a member???
worked... looks pimp
What all did you have to do to get it to fit tho? When we put mine on my buddys del sol there was like 2" gap on both sides....
Kinda takes 2 people. One to hold the lip in place the other to drill.
While the one guy holds the lip the other drills about 6+ holes thru the lip into the bottom of the bumper. You kinda have to flex the lip a tad. Then i also put to bolts on the ends...
Its hard for me to explain, and the fact that i did it a year and a half ago doesnt help...
If you want PM me and i can try to get some pics of the lip on the bumper cover, up close. My car is all torn apart right now so it wouldnt be hard.
There is a small gap on mine, we are talking a mm or 2. that was caused by my dumb *** driving over the lip before i installed it.
it definately fits. the key is getting self-drilling screws (aka self tapping screws) from home depot. It will also be a lot easier if you can take off the bumper.
once u have the bumper off, line up the middle of the lip to the middle of the bumper, drill one screw in the middle to keep the lip tight. then move along the sides, use one hand to stretch the lip and the other to drill the screws. there will be a small lip underneath the lip about halfway from the middle, use a screw there so there will not be a gap where the lip curves around the bumper. then when you get to the end where the lip wraps around the bumper, use one more screw there.
use as many screws as you need. i used a total of 8 screws for mine.
here are some pics: https://honda-tech.com/zerothread?id=1184740
James
James
CRXVTI106
Jul 22, 2002 04:10 PM
