car blowing out white/blue smoke
Old Mar 29, 2005 | 07:50 AM
racingfan's Avatar
Default car blowing out white/blue smoke
well i have a fresh ITR short block in my car now, the car start smoking like BBQ whenever I start up the car, I know its burning the oil, but do you ever have the same problem with you doing engine swap? and what will the problem you think?
Old Mar 29, 2005 | 09:09 AM
chameleon's Avatar
Default Re: car blowing out white/blue smoke (99AllMotor-GSR)
it could be anything from the rings to your valve seals, not saying this is your case but sometimes it could be the most stupid things, did you get a leakdown done?
Old Mar 29, 2005 | 09:14 AM
racingfan's Avatar
Default Re: car blowing out white/blue smoke (chameleon)
whats leakdown?
Old Mar 29, 2005 | 09:27 AM
chameleon's Avatar
leakdown basically lets a mechanic tell where the air is leaking out possibly where the oil thats burning is coming from. and btw what do you refer to as "fresh" ?
Old Mar 29, 2005 | 09:38 AM
racingfan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">what do you refer to as "fresh" ?</TD></TR></TABLE>
BRAND NEW
Old Mar 29, 2005 | 09:46 AM
89s1's Avatar
you might be burning coolant (antifreeze) in your engine, IT may be the headgasket.
If the gsr head isn't warped (and you had it checked) then i would maybe look into the coolant level, if you see adrop in the level of coolant, but not oil, I would say to check or replace the ehadgasket and the head/block deck surfaecs.
Old Mar 29, 2005 | 09:49 AM
racingfan's Avatar
Default Re: car blowing out white/blue smoke (89s1)
I'd replace a brand new head gasket when I put the head back on...
I have just water in my radiator now, that might be why.
Old Mar 29, 2005 | 11:09 AM
2k.civic.si's Avatar
water in an aluminum block...guess youll get to find out how many minerals are in your water....your only supposed to run 100% honda coolant....and when i puffed out blue/white smoke on startup it was because of my valve seals
Old Mar 29, 2005 | 11:15 AM
projectTeG's Avatar
Default Re: car blowing out white/blue smoke (2k.civic.si)
yea sounds like you valve seals, my car smoked blue smoke at idle and start up, ...i replace the valve seals and problem went away
ACrite3404
Jun 27, 2008 02:31 AM
djstain
Jun 1, 2006 09:58 PM
MrPotatoeHead
Mar 16, 2005 05:26 AM
voofee
Dec 11, 2004 07:41 AM
Honda Crx
Apr 21, 2004 09:47 AM
