accord lx 98 low beam?
Old Mar 29, 2005 | 06:54 AM
lv69's Avatar
Default accord lx 98 low beam?
i'm looking for the wiring diagram for accord lx 1998 2.3 vtec. my headlights lowbeam doesn't light up. high beam and daylights working fine, look all my fuse, swap my headlights relay no fix. please help me
Old Mar 29, 2005 | 03:28 PM
matt_in_sd's Avatar
Default Re: accord lx 98 low beam? (lv69)
Any chance both bulbs are burned out?
Otherwise there is a different relay for each side, chance of both failing at the same time is slim, but they are located in underhood fuse box. Next up is the DRL module, drivers multiplex control unit, or the light switch itself. There are minor differences for the EX model, also does your have flash to pass or auto off? When you start the car the DRL should be on, if you turn on the headlights will the DRL turn off? The drivers multiplex control unit is a couple of hundred, I dont know what the DRL module is.
Old Mar 29, 2005 | 05:22 PM
someone else's Avatar
It Wasn't Me!
Default Re: accord lx 98 low beam? (matt_in_sd)
I know we've seen problems with the DRL module on 5th gen Canadian accords a couple of times in my shop. I only recall seeing one 6th gen Canada car at our shop. But I see alot of Can. Odysseys in the shop and don't remember having any probs. Have you tried the bulbs? Sorry if that seems like a dumb question but DRL cars are much more likely to have both go at the sqame time.
madtom
Oct 1, 2015 02:57 PM
sungkyupak
Aug 12, 2004 08:05 AM
civicboisi
Jul 23, 2003 09:30 AM
Finest
Sep 12, 2002 06:12 AM
Xippi
Jan 9, 2002 11:36 PM
