92 accord <95' h23a swap...axles????
Old Mar 28, 2005 | 11:48 PM
B18CUL8R's Avatar
Default 92 accord <95' h23a swap...axles????
i have a 95 h23a engine and trans in my 92 accord lx....
i converted the car from auto to manual...
in the process i removed the factory automatic mount on the actual chassis of the car and welded in the 5 speed cb trans mount...
when we put in the engine in the studs for the upper trans mount did not line up with the holes on the 92-95 h23 motor mount i had purchased. BUT the holes matched up to these circles on the trans where it looked as if studs could go...so i drilled and tapped the holes and put the studs into them..VOILA! perfection....
NOW HERES MY PROBLEM
i bought MT 92-95 prelude axles for the swap and the right side went in fine but the left side(drivers) was about a half inch too long...so i took it back and bought a MT CB7 axle...that one was too short or something i forget all i know is it didnt fit either. but anyway when all kinds of money was spent and all was said and done i ended up with
1-cb7 outer joint
1-integra gsr shaft
1-92-95 prelude inner joint
i dunno wtf we were thinking but we got desperate and the thing acutally fit pretty good and after pounding the sh*t out of my car during the test drive it seemed all good so we left it alone...now 9 months have gone by and the axle is starting to make noise and vibrate quite a bit and i want to replace it but i dont want to buy 3 driveshafts just to make one
BASICALLY I JUST NEED TO KNOW IF ANYONE HAS THIS SAME OR SIMILAR SWAP OR HAD THIS SAME DILEMMA.....AND ALSO WHICH AXLES THEY USED THANKS
Old Mar 29, 2005 | 10:43 PM
Nick H's Avatar
New User
Default Re: 92 accord <95' h23a swap...axles???? (B18CUL8R)
just measure it correctly and contact driveshaftshop.com ....they can probably get something hooked up for you...
Old Mar 30, 2005 | 04:50 AM
Monkey Fing a Coconut's Avatar
Default Re: 92 accord <95' h23a swap...axles???? (Nick H)
4th gen accord with h series swap (h22 or h23, or any f series for that matter [other than s2k]) uses stock accord axles and int shaft, so ditch the gsr and lude shafts and get all cb7 ones
Old Mar 30, 2005 | 10:22 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: 92 accord <95' h23a swap...axles???? (twistedbydezign)
What he said^^^^^.
http://cb7tuner.com/
These guys are the kings of 4th gen swaps. As Am I
Old Mar 30, 2005 | 10:21 PM
B18CUL8R's Avatar
^^^^omg i cant beleive i forgot about that sight....but yeah ****** axle is pissin me off.....i'll see what i can do thanks guys
Old Apr 13, 2005 | 10:24 AM
inep01's Avatar
Default Re: 92 accord <95' h23a swap...axles???? (cb7-R)
Grupple
Transmission & Drivetrain
Jun 18, 2013 06:17 PM
deltazlt
Jan 25, 2013 02:46 PM
dartonh22
Jan 31, 2008 05:08 PM
pinecone
May 12, 2007 07:30 PM
ESP-net
Mar 4, 2007 07:19 AM
