COMPILATION VID...
Old Mar 28, 2005 | 10:40 PM
DC5RK20A's Avatar
Default COMPILATION VID...
Just combined some old clips into 1, about 7 min and 15 sec long.
First is 53Mb in size and shown in 1Mb/sec 856x480 EDIT: NOT WORKING
Second is 19Mb in size and shown in 340kb/sec 428x240
Third is for those of you on dial-up, 2.7Mb and 48kb/sec 216x120
Are there still people on dialup?
Enjoy!
RIGHT CLICK/SAVE AS
HALF SIZE
DIAL UP
Yeah I know, you have seen a couple of them already, shoot me! As soon as I have the car back, new clips will be made. I watch these almost everyday, just because I miss it so much. IT HAS BEEN A LONG 3 MONTHS.
Modified by DC5RK20A at 9:56 PM 3/29/2005
Old Mar 29, 2005 | 02:00 PM
JDM2ndGen's Avatar
Default Re: COMPILATION VID... (DC5RK20A)
nice video ...i love the way yuour DC5 sounds looks and handles ...were you rev matching into 1st? and your friends EP3 was hot also ...
Old Mar 29, 2005 | 02:05 PM
DC5ITR329's Avatar
what offset of MF10s are you running and what size tires?
Old Mar 29, 2005 | 02:14 PM
DC5RK20A's Avatar
Yes I was rev-matching as much as possible. Thanks for the props.
The MF10s are the 55 offset, the 45 offset on the JDM setup would cause me to scrub tire without rolling the fender. The tires are 215/45/17
Old Mar 29, 2005 | 02:25 PM
JDM2ndGen's Avatar
Default Re: (DC5RK20A)
cool ...i didnt think you could rev match into 1st i thought where was a lock or something ...
Old Mar 29, 2005 | 02:28 PM
DC5RK20A's Avatar
Default Re: (JDM2ndGen)
Maybe at very high rates of speed? Not sure, kind of like the lock-out for reverse. The top speed that I reached in the gymkana vids was about 90-95km/h(56-59mph).
Old Mar 29, 2005 | 02:31 PM
JDM2ndGen's Avatar
yea i think your right ...about the high rate of speed thing .. what suspension are you running ... never mind i just looked at your aig lol
Old Mar 30, 2005 | 01:36 AM
Charbon Sty's Avatar
very cool vid
you guys have some very respectable rides
whats the story with the oil starvation? any reason this happened?
Old Mar 30, 2005 | 06:39 AM
f1nal zeros's Avatar
Very nice video bro. I see you are also a member of the ITR uk forums and clubrsx. I'm there as well.
Old Mar 30, 2005 | 07:23 AM
lessthndan's Avatar
Default Re: (f1nal zeros)
sweet vid, good driving!
Old Mar 30, 2005 | 01:31 PM
DC5RK20A's Avatar
Default Re: (kelsonmassif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelsonmassif &raquo;</TD></TR><TR><TD CLASS="quote">very cool vid
Yeah Honda should of baffled the stock oil pan, but they didn't. The K series has very narrow bearings and the slightest loss of oil and they are TOAST. Thanks.
Mando, yes I have seen you all over the net as well.
lessthndan, thank you, though I know I still have alot of improving to do. That will happen with more and more driving!
Old Mar 30, 2005 | 02:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5RK20A &raquo;</TD></TR><TR><TD CLASS="quote">
lessthndan, thank you, though I know I still have alot of improving to do. That will happen with more and more driving! </TD></TR></TABLE>
It was sad hearing what happend to the car bro, I almost had my engine have oil starvation. I caught it in time thou. I was on the track coming around a turn onto the straight away. Vtec engages at 6k rpm and I noticed the car not go into vtec but rather lag and vtec engaged at 7k. This alarmed me so I just coasted around the track to get back to the pits and pulled off. Check the oil only to find there was no oil. Engine had burned it all. I added 3 qts and it barely reached the 1st dot. Since then I have upped the weight of the oil used and added a oil cooler.
Last event I did not burn one drop of oil.
Old Mar 30, 2005 | 03:38 PM
DC5RK20A's Avatar
An oil cooler will be the next thing I add. Just have to save funds. The baffled/trap oilpan is just a sort of fix for the problem. It should help dramatically, but the oil temps still get quite high, at least with how I drive.
Old Mar 30, 2005 | 03:44 PM
zulustypes's Avatar
Oil Cooler? which one and how bad was the install and price of the unit?
That DC5R is bad ***... makes me wish I had an LSD to pull out of the corners like that... I have JIC coilovers and some progress sway bars and the car handles pretty good.. but I can see where if I had an LSD it would make it 10 times better pulling you out of the corners
Old Mar 30, 2005 | 04:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5RK20A &raquo;</TD></TR><TR><TD CLASS="quote">An oil cooler will be the next thing I add. Just have to save funds. The baffled/trap oilpan is just a sort of fix for the problem. It should help dramatically, but the oil temps still get quite high, at least with how I drive. </TD></TR></TABLE>
Oil cooler was pieced together through http://www.aaroadracing.com.
They have a custom set up that works very well. 13 row oil cooler, sandwhich plate, braided lines, and end links for around $300.oo.
Just give them a call or shoot them an email and let them know Armando recommended you. I was thier test car for the oil cooler install.
I had to do this, I was cautious of burning more oil. So next on my list is a electronic accusump oil pump, oil pressure/temp gauge. This should help me do well on the tracks regarding oil burning. After that I may go with a baffled oil pan, maybe the one you run DC5Rk20A. Let me know how it runs.
Old Mar 30, 2005 | 04:21 PM
Sorry for going off topic guys/girls but maybe this can help you out DC5RK20A and zulustypes. Here are pictures to help you guys out.
Old Mar 30, 2005 | 05:59 PM
zulustypes's Avatar
thanks a lot!! car looks sweet! but it wont work for me since I have a big *** intercooler already taking up all the space.
Old Mar 30, 2005 | 06:21 PM
DC5RK20A's Avatar
$300 for the total kit? Damn oil coolers are so much cheaper in the states compared to here. It would cost me about $850+ here. I might be able to swing this earlier now.
Thanks alot Armando. Really appreciate it.
Chris
Old Mar 31, 2005 | 06:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5RK20A &raquo;</TD></TR><TR><TD CLASS="quote">$300 for the total kit? Damn oil coolers are so much cheaper in the states compared to here. It would cost me about $850+ here. I might be able to swing this earlier now.
Chris</TD></TR></TABLE>
Hey bro if you want pm me and I can give you the number to the shop I got mine from. They do shipping. It weights like 3-5 pounds for everything so shipping will be nothing.
Old Mar 31, 2005 | 10:33 AM
JMU R1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">cool ...i didnt think you could rev match into 1st i thought where was a lock or something ...</TD></TR></TABLE>
You can downshift into first but I find I have to double clutch to match revs properly when downshifting into first.
WattsUp
Aug 13, 2011 08:20 AM
ww927bin
Audio / Security / Video
Jan 25, 2010 10:03 PM
SPOOLINmatt
Nov 18, 2008 12:25 PM
DC5RK20A
Mar 29, 2005 11:47 AM
danimal
Aug 28, 2004 07:00 AM
