E brake light problem.....?help?
Old Mar 28, 2005 | 10:20 PM
mist sITR's Avatar
Default E brake light problem.....?help?
i'll try to explain this the best i can
whenever i'm starting from a stop or slow speed and give it alot of gas 3/4 throttle+ my E brake guage lite comes on and then turns back off once i'm up to speed?? any idea what this could be it's really annoying..
thanks in advance
Old Mar 29, 2005 | 03:49 AM
cjames235's Avatar
Default Re: E brake light problem.....?help? (mist sITR)
you could be a little low on brake fluid.... check that
Old Mar 29, 2005 | 04:18 AM
Opie's Avatar
-Remove brake fluid resevoir cap
-Add fluid if low
-Clean off crap building up under the resevoir cap
G'luck.
Old Mar 29, 2005 | 04:45 AM
ebelp's Avatar
Default Re: (opie)
Jiggling the "floater" in the main reservoir works for me.
Man that sounded ghey...
Old Mar 29, 2005 | 06:45 AM
typer_801's Avatar
Sadly, I had the exact same thing happen on my R. I fixed it, but don't remember what I did. DOH! It occured after I did my clutch change, so it was probably some wire I didn't connect back correctly on the install.
Old Mar 29, 2005 | 09:11 AM
mist sITR's Avatar
Default Re: E brake light problem.....?help? (typer_801)
thanks guys, it's been taken care of. it was low on fluid but still above the min. mark by quite a bit. i topped it off and the problem's gone..
u all get
Old Mar 29, 2005 | 02:33 PM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mist sITR &raquo;</TD></TR><TR><TD CLASS="quote">it was low on fluid but still above the min. mark by quite a bit.</TD></TR></TABLE>
I would be very very suspicious to know why if I were you. Check all your lines. You're not supposed to "burn" off brake fluid like oil. May be signs of a bigger problem.
Not that we should burn off oil either
Old Mar 29, 2005 | 02:51 PM
Kenso's Avatar
HT White Ops
Default Re: E brake light problem.....?help? (opie)
Low brake fluid level may not be indicative of a problem. As the pads wear the brake caliper pistons extend further towards the rotor. This effectively increases the volume of fluid held in each caliper, causing the fluid level in the reservoir to drop. Check and see if your pads are worn to the point of needing replacement.
Old Mar 29, 2005 | 06:08 PM
Chris F's Avatar
Default Re: E brake light problem.....?help? (Kenso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso &raquo;</TD></TR><TR><TD CLASS="quote">Low brake fluid level may not be indicative of a problem. As the pads wear the brake caliper pistons extend further towards the rotor. This effectively increases the volume of fluid held in each caliper, causing the fluid level in the reservoir to drop. Check and see if your pads are worn to the point of needing replacement.</TD></TR></TABLE>
^^^ I'm with this dude. Pads and rotors wear, brake fluid takes up the slack.
-Chris
Old Mar 29, 2005 | 10:49 PM
mist sITR's Avatar
Default Re: E brake light problem.....?help? (Chris F)
i know it's from the rotor wair. the cobalt spec B's are eating away the rotor nicely
Old Mar 30, 2005 | 09:07 AM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Pads and rotors wear, brake fluid takes up the slack.
Point noted. Keep us updated
Old Mar 30, 2005 | 10:10 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">I would be very very suspicious to know why if I were you. Check all your lines. You're not supposed to "burn" off brake fluid like oil.</TD></TR></TABLE>
As pads wear = fluid level drops
Old Mar 30, 2005 | 11:20 AM
Opie's Avatar
Default Re: E brake light problem.....?help? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
As pads wear = fluid level drops </TD></TR></TABLE>
Point noted. Keep us updated </TD></TR></TABLE>
trevorjohn88ef
Mar 24, 2008 10:03 AM
Ha7chB4cK
May 3, 2005 06:06 PM
type r 01-1063
Apr 3, 2003 11:04 PM
ITR#JohnBasedow
Dec 9, 2002 08:01 AM
nsx-Animal
Jul 29, 2002 11:54 AM
