ok quick its goin to happen tomarrow b16 or single with turbo
tomarrow i am either dropping my b16 swap in my crx that has a custom ecu, act clutch and underdrive pulley. OR my friend will trade me his 99 single cam v-tec with a greddy turbo, cam gears, inter cooler, underdrive pulley,ignition system, type-r fuel pump,blow off v,custom integ. ecu,act type 3 racing clutch and v-tec controller. I need some ensight QUICK.....WHAT SHOULD I DO.
If I had to do it all over again, I'd go sohc turbo. So easy to get parts for those motors, and the trannies are replaceable.
On the other hand, the B16 is a better platform, provided the tranny doesn't die on you which can get expensive.
I have a B16 in my CRX as well, and if had to do it over again I would have gotten the type-r motor. You cannot beat the B-series platform!!!!
