i just installed my FPR.... is this right ?
Old Mar 28, 2005 | 09:16 PM
red_ek_hatch's Avatar
Default i just installed my FPR.... is this right ?
i just installed a B&M fuel pressure regulator and gauge . we installed the gauge first and it showed it was at 34 psi stock . is that about right with a b16 sir II ????
my mods are : aem intake , comptech header, catback exhaust, skunk2 intake manifold . im also running a ITR ECU . what should i set the psi on the regulator at ?
like i said before , it showed 34 psi at stock setting before we did the B&M fuel pressure regulator . thanks in advance .
Old Mar 28, 2005 | 10:26 PM
athoughts's Avatar
Default Re: i just installed my FPR.... is this right ? (red_ek_hatch)
should be fine, stock i thought is around 38psi i believe?
Old Mar 28, 2005 | 11:23 PM
Default Re: i just installed my FPR.... is this right ? (athoughts)
well actually my question is : what should i set my psi at with the B&M FPR ?
Old Mar 29, 2005 | 06:58 AM
DelSolDon's Avatar
just getting ready to do my fpr too. stock according to haynes (yea, i know, should be using helms) is 30-38 with vacuum attached and 40-48 w/o. i've read to start at 40 w/ vacuum attached if you just have bolt-ons and adjust down from there. i've also read that a couple people ran 40 and thought it was too high, so they knocked it down to like 37 and ran much better. let me know how yours goes and what you set it to. thanks.
Old Mar 29, 2005 | 07:29 AM
xtrafastcivic's Avatar
Default Re: i just installed my FPR.... is this right ? (DelSolDon)
you're suppose to set it with the hose off to simulate WOT
Old Mar 29, 2005 | 09:25 AM
DelSolDon's Avatar
Default Re: i just installed my FPR.... is this right ? (XtraFastCRX)
so set it at like 48 with the hose off would be good?
Old Mar 29, 2005 | 04:35 PM
DelSolDon's Avatar
Old Mar 29, 2005 | 04:47 PM
athoughts's Avatar
set it around 38, leave it stock until someone that knows what thier doing tunes it
Old Mar 29, 2005 | 10:34 PM
with intake header and exhaust he should add a little more fuel you can try 48.. check your plugs after a couple of miles and of course famous butt dyno always works .. if you have a cat i dont suggest too rich..
Old Mar 29, 2005 | 11:31 PM
yeah i also think i should wait till an experience tuner tunes it , along with other parts . we set it at 36 psi . originaly it was set at 34psi . wich i think either or is preatty low but i just dont wanna mess something up . thanks
Old Mar 30, 2005 | 11:55 AM
DelSolDon's Avatar
my opinion, haynes says stock can range from 30-38 with vacuum and 40-48 without, so i'm gonna set mine at 37-38 with vacuum and 47-48 without. and personally i think its stupid to pay someone to dyno-tune your car to adjust an FPR.
Old Jun 30, 2005 | 01:40 PM
elusive123's Avatar
are u guys doingthis with the key on the on position or at idle
im a curious
Old Jun 30, 2005 | 03:49 PM
DEMNTD1's Avatar
Default Re: i just installed my FPR.... is this right ? (elusive123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elusive123 &raquo;</TD></TR><TR><TD CLASS="quote">are u guys doingthis with the key on the on position or at idle
im a curious </TD></TR></TABLE>
At idle with vacuum off.
lyncoors
Mar 25, 2010 07:13 AM
85mm LS VTEC
Aug 27, 2005 03:01 PM
red_ek_hatch
Mar 28, 2005 09:28 PM
honda9369
Sep 9, 2004 07:04 PM
93_hatch
Aug 26, 2004 02:03 PM
