Barely pass smog, but very high O2%, what is it?
Old Mar 28, 2005 | 08:11 PM
PandaBear's Avatar
Default Barely pass smog, but very high O2%, what is it?
Just did smog check and barely pass, here is the result:
15mph - 1813 rpm
CO2% 15.3
O2% 20.6
Max Avg Meas Type
61 9 61 HC
0.54 0.02 0.43 CO
467 57 386 NO
25mph - 1877 rpm
CO2% 15.3
O2% 20.6
Max Avg Meas Type
45 7 26 HC
0.53 0.03 0.07 CO
754 50 231 NO
Just did a tune up 1500 miles ago and a spark plug change. So I am lucky that I barely pass the 15mph HC, and everything else is getting up there. Now what I don't understand is why every one else have almost zero on O2 and I have 20%, isn't air only 23% O2? Does that means I am leaking like crazy?
Oh yeah, it is an LS auto with 150k miles on it.
Old Mar 28, 2005 | 10:17 PM
PandaBear's Avatar
Default Re: Barely pass smog, but very high O2%, what is it? (PandaBear)
Just looked on google, atmosphere only has 20.7% O2 and that ideal burn CO2 is 15.5%, it is clearly the smog shop I went to has a modded smog machine that try to get around those 2 number, seems like only HC, CO, and NO is read here.
Old Mar 29, 2005 | 03:09 AM
non-VTEC's Avatar
the machine they were useing could probably be out of calabration. just ingore the O2% values and just worry about you CO% which looks pretty rich........
i would say its possible your o2 sensor is not working or they didnt properly warm the car/converter up prior to the test.
Ruben19
Jul 7, 2009 01:18 PM
Ran4it2
May 8, 2008 03:29 PM
who00knows
Feb 13, 2004 07:49 PM
ATS*Mark
Dec 29, 2003 09:07 PM
