Need help on fixing dents
For some odd reason, only one side of my crx was dented by my dad. I think he hates his passengers or something.
Anyways.
Here are pictures of the dents I want to fix:
This one looks like I can push it out from the other side, if I unscrew these screwes on the front wheel well, does it give access to that area? Only reason I ask before trying is I cant find a screwdriver tiny enough to fit between the wheel and screw to turn.
Red are screws I want to try. Green is the other dent.
The other dent is on the passenger door. The black trim is also dented. Any DIY ways to fix this?
You guys are awesome
Anyways.
I know nothing much about body work - but if you want to DIY on those dents, good luck! I bet you'd have much better luck going to a paintless dent repair place by where you live. The black trim piece, BTW, will probably need to be replaced, as I don't think the dent will "pop" out of it.
Alex
Alex
Andres-eh2
Oct 29, 2003 07:52 AM
