Oil in Spark Plugs.
Old Mar 28, 2005 | 05:35 PM
Amer_C's Avatar
Default Oil in Spark Plugs.
I need some help assessing what the problem is. My sister drives a '96 Honda Accord and on the way home her check engine light comes on. A friend of hers tells her to check the spark plugs and wires to make sure that they are all good and not causing a cylinder misfire. When I got home I checked all the spark plugs and all of them had oil in them. There was no oil in the cylinders but the spark plugs were drenched it oil. Now I know that that is probably an gasket and O-ring issue. My question is could this be causing the check engine light to come on? or could this be causing a cylinder misfire?
Old Mar 28, 2005 | 05:56 PM
BDietrich84's Avatar
Default Re: Oil in Spark Plugs. (Amer_C)
i would jumper the ecm and figure out what code its putting out and go from there. as for the oil around the plugs, your valve cover gasket could be leaking.
Old Mar 28, 2005 | 07:05 PM
SIMATIC's Avatar
Default Re: Oil in Spark Plugs. (BDietrich84)
go to autozone they check ecu codes for free...if a number comes up look it up online n find out what it is, i would change the plugs, gasket, n then oil.
Old Mar 28, 2005 | 10:08 PM
CB7VTEC's Avatar
cam tower o-rings, ask your local dealer. get the spark plug tube seals and valve cover gasket while your at it
Old Mar 29, 2005 | 04:49 AM
Amer_C's Avatar
Thanks guys I am on my way to autozone to get a code reading and Ill get what ever other gaskets and o-rings I need.
Old Mar 29, 2005 | 05:44 AM
Amer_C's Avatar
I just got back for Auto Zone and they gave me a code reading of P0420. The guy at Auto Zone said that this was an oxygen sensor in bank #1. I checked it online and it tells me that it's the catalytic converter. What do you guys actually thing the code is?
Old Mar 29, 2005 | 06:24 AM
someone else's Avatar
It Wasn't Me!
Default Re: (Amer_C)
P0420 is a cat code. The plug tube seals at the top of the tubes are your most likely culprit for the oil in the plug tubes. Thye cam tower o-rings are the ones at the bottom that to replace them you have to pull the cams and rocker assembly. Not an easy job. You then have to readjust the valves. Depending on mileage and abuse it is more likely that the tube seals at the top are leaking instead of the cam tower o-rings.
bwiissofly
Jun 5, 2013 10:24 PM
BBallz24
Feb 16, 2009 06:17 PM
diewX3
Feb 24, 2005 04:08 PM
1.8Tea
Aug 27, 2004 07:54 PM
Mike17
Feb 11, 2004 02:31 PM
