Suspension & Brakes Theory, alignment, spring rates....
Adjusting PSI of OMNIPOWER coilover
Old Mar 28, 2005 | 05:32 PM
JDMmaster's Avatar
Default Adjusting PSI of OMNIPOWER coilover
While taking apart my coilover today(replacing broken lower collar) i noticed the little flat head screw at the bottom of the damper. so i took it off and found a air hose connector . So my question is, does anybody here have experience with adjusting the PSI in OMNIPOWER coilovers? what are the perks of being able to adjust the PSI if any? and finnaly what is the factory PSI the damper should be at? If these are anything like my rockshox on my mountain bike, then it will be fun playing around with the psi at the track.
Old Mar 29, 2005 | 03:08 PM
JDMmaster's Avatar
Default Re: Adjusting PSI of OMNIPOWER coilover (JDMmaster)
Nobody???
Old Mar 29, 2005 | 03:40 PM
nonsense's Avatar
first you'd need a nitrogen tank ... then .... well call Omni and ask I guess
Old Mar 29, 2005 | 04:22 PM
Tyson's Avatar
got a pic?
V6@dragracingpr
Oct 15, 2010 12:27 PM
fastlude69
May 13, 2003 07:30 AM
DXRacer
Feb 21, 2003 07:04 AM
