Band Saw Blade
Old Mar 28, 2005 | 04:37 PM
Motorhead_AZ's Avatar
Default Band Saw Blade
Hey guys,
I was wondering what brand of band saw blades you use and where you buy them. I have a Harbor Freight vertical/horizontal band saw and so far, I've gone through 3 of their blades. What happens is after I make a cut on thicker materials (sch 10 SS for example), a bunch of teeth on the blade just disappear. The saw itself is really nice and I'm happy with it, but the changing blades so frequently is getting tiring. I apologize for the bad pictures, but that's what it looks like. There are sections as long as 5-6" long that have no teeth left on them.
Thanks in advance
Old Mar 28, 2005 | 04:42 PM
hybrid_KJ's Avatar
Default Re: Band Saw Blade (Motorhead_AZ)
I've been using that saw and cutting sch 40 and really have not had that problem even with the 10 TPI blade. I did break one blade but other than that they have not had any problems.
Old Mar 28, 2005 | 06:06 PM
triple_s1x's Avatar
Default Re: Band Saw Blade (hybrid_KJ)
I've used that saw too, its not terrible. Just make sure when your cutting the SS you are going at the slowest speed.
Old Mar 28, 2005 | 06:40 PM
Default Re: Band Saw Blade (triple_s1x)
Thanks for the replies, however, I didn't ask you to tell me how to operate the saw, or whether you like yours or not. I'm more interested in knowing what brand of blades you have used and your feedback on them.
Thanks
Old Mar 28, 2005 | 07:20 PM
Keyhole's Avatar
https://honda-tech.com/zerothread?id=1192922
Old Mar 28, 2005 | 09:03 PM
triple_s1x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motorhead_AZ &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies, however, I didn't ask you to tell me how to operate the saw, or whether you like yours or not. I'm more interested in knowing what brand of blades you have used and your feedback on them.
Thanks </TD></TR></TABLE>
Wow buddy, i have used the shitty blades from HF and i used expensive blades from Lenox. They both work fine, like i said before but i forgot you dont need instructions when using a **** blade like for example the blades they sell at HF and the blade it comes with you need to cut at the slowest speed.
Old Mar 29, 2005 | 08:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by triple_s1x &raquo;</TD></TR><TR><TD CLASS="quote">
Wow buddy, i have used the shitty blades from HF and i used expensive blades from Lenox. They both work fine, like i said before but i forgot you dont need instructions when using a **** blade like for example the blades they sell at HF and the blade it comes with you need to cut at the slowest speed. </TD></TR></TABLE>
Thanks for another useless reply. The saw has always been on the slowest speed (smallest motor pulley, largest saw pulley). So it's not the operator error that chews up the blades. I know how to operate a power tool. All I'm interested to know is what brand blades you guys have used and your feedbacks on them.
Old Mar 29, 2005 | 08:23 AM
IHaveTurbos's Avatar
I use these with the HF bandsaw and cut SS for collectors and mild steel all the time:
http://www.use-enco.com/CGI/INSRIT?PMAKA=371-0404
And I have not had a problem with them. I usally get about 1 month from each blade with cutting about 4 hours everyday.
The problem with the HF blades and using them on the SS is they are not Bi Metal, so when you use them on SS the SS rips the teeth off.
3s0n3
Welding / Fabrication
88
Mar 9, 2009 05:50 PM
1 2 NV
Jun 25, 2007 08:45 PM
ATS*Mark
May 5, 2006 11:25 AM
spoon063
Honda Motorcycles
Nov 23, 2005 08:41 PM
uNF$@#!
Mar 15, 2005 07:46 AM
