Swap 88 fuse box into 91???
I got a 91 civic, recently converted to a manual. My ecu is throwing a code 20 because iam using an 88ecu. i have an 88 fuse box to put in but i have a little problem. The 88 ecu has an extra plug/harness for the eld. 90-91 civics dont use the eld. So in order to install an 88 fuse box with a functional eld id have to find the plug for the eld (if 90-91 civics even have them) or run wires to hook it up (which i dont really want to do). if anyone has done this b4 or has any ideas id appreciate it
Id show a pic of what i mean if i knew how to insert a pic lol
wait, i was confused and it was 3am when i posted, but besides the point are the 88 ecus different then 91?
i dont know they might be besides the point that u cant chip them, i doubt they are different..
not sure though, free bump
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_HB »</TD></TR><TR><TD CLASS="quote">They are different. in 88 they used an eld in the fuse box, in 90-91 they didnt use the eld.</TD></TR></TABLE>
HUH!? all USDM civics had ELDs, right? i have a 91 and it has a ELD. just dummy up a rester ladder so the ecu gets a voltage and dosent thow a code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">
HUH!? all USDM civics had ELDs, right? i have a 91 and it has a ELD. just dummy up a rester ladder so the ecu gets a voltage and dosent thow a code.</TD></TR></TABLE>
Correct they all have the ELD, just in different locations.
