problem getting into gear
Old Mar 28, 2005 | 03:35 PM
dustinO's Avatar
Default problem getting into gear
i have an 88 civic...i just did a B18a swap...got it running yesterday and it wouldnt go into gear when the motor was running...it would just grind, yet when the car is off it goes into gears fine...it is an LS cable tranny with a ACT 6 puck unsprung clutch with an extreme pressure plate and pro lite flywheel...i tried using the stock EF clutch cable but alas it snapped....now i am just using the 92 integra clutch cable that was originally used on the motor when it was in the 2nd gen teg....any ideas?
Old Mar 28, 2005 | 03:46 PM
sporkcrx's Avatar
Default Re: problem getting into gear (integraca)
Probably needs to be adjusted, the clutch sounds like it's dragging.
Old Mar 28, 2005 | 05:06 PM
dustinO's Avatar
Default Re: problem getting into gear (sporkcrx)
allready tried adjusting the clutch cable...nothing happening
Old Mar 28, 2005 | 07:29 PM
acuratech's Avatar
If the clutch plate is not alighned perfectly with the pilot bering when you installed the tranny, it will cause a bind between the input shaft, and the clutch plate splines. How hard was it to get the trans bolted to the engine? If you forced it then you are going to have to pull the clutch back apart, and check for damage to the clutch plate, and the input shaft splines.
Old Mar 28, 2005 | 11:08 PM
dustinO's Avatar
when i put the tranny on the motor was out.. so it was easy slide right in
and i'd be impossible for the clutch plate to not be alligned with the pilot bearing.. the tranny wouldnt bolt up at all if that was the case
Old Mar 29, 2005 | 06:27 AM
kim_2_da_chee's Avatar
Default Re: (integraca)
Try adjusting that screw under your tranny. I think it's 14mm or 17mm bolt.
From the passenger side, you can see 2 bolts under your tranny. Slightly loosen the one that is further away from you. (I wish I had a picture) Shove a washer on the bolt and tighten it. Becareful because there is a spring that comes out from that hole.
Thats all I can think of if it's not a clutch related problem.
Old Mar 29, 2005 | 03:41 PM
acuratech's Avatar
Default Re: problem getting into gear (acuratech)
OK, just trying to help you out. Slight possibility that I am wrong, but thats where I have my money...
Eggman
May 1, 2018 11:04 AM
chaucer
20
Nov 15, 2012 11:29 PM
WagoCan_Brownie
May 27, 2012 08:30 AM
92TEGGYGSR
Jul 12, 2004 04:56 AM
bloodyknuckles
Jun 4, 2004 07:26 PM
