Suspension Problem I Think ???Help???
95 Civic EX is blowing trough tires like crazy and all of a sudden when I cange lanes to the right the car starts to vibrate like crazzy. I thought the tire was going to fall off. I got out and checked to make sure all of thee tires wher on tight and they are. Could this be a control arm broblem. What should I look for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi »</TD></TR><TR><TD CLASS="quote">vibrating in the front or back???
if its front sounds like a tie rod end</TD></TR></TABLE>
yes especially if hes "blowing through tires like crazy"
Hows the camber on the car?
car is droped 1 1/4 and I drove arround for about 2 years befor I started wearing trought tires. sometimes on the highway the car will suddenly pull to the right and it mainly starts vibrating when I come out of a corner.
I did a full inspection under the ar and everything seams strait and the usshings arnt that bad. The front lower ball joints are alittle squished. Howerver when I went to the back I noticed the rear trailing arm bushungs are compleatly pulled apart could this case the vilant shaking at times and the tire wear?
EK FLY
Mar 29, 2006 04:08 PM
