D16Z6 CRX SWAP(wiring harness)
Old Mar 28, 2005 | 02:51 PM
madswapper's Avatar
Default D16Z6 CRX SWAP(wiring harness)
Does anyone know how to modify a CRXdx wiring harness using a D16Z6 wiring harness? Also, is there anything I am going to need for the new P28 ECU.
thanks.
Old Mar 28, 2005 | 02:56 PM
CRX_Control's Avatar
Default Re: D16Z6 CRX SWAP(wiring harness) (madswapper)
Use stock harness...obd1 dizzy , conversion harness , 4 wire o2 sensor , the search funtion.
Old Mar 28, 2005 | 03:07 PM
madswapper's Avatar
Default Re: D16Z6 CRX SWAP(wiring harness) (CRX_Control)
I have already searched and I need to know the exact instructions or a diagram from anyone who has the knowledge.
k thx
Old Mar 28, 2005 | 03:10 PM
gnar kill's Avatar
when you buy the conversion harness....which you should.....it will come with instructions
Old Mar 28, 2005 | 03:36 PM
madswapper's Avatar
Default Re: D16Z6 CRX SWAP(wiring harness) (gnar kill)
thanks for the reply gnarkill...where do you suggest buying the kit from?
Old Mar 28, 2005 | 04:58 PM
NikoZai's Avatar
<FONT SIZE="4">http://www.rywire.com</FONT>
We've got you covered. 4-wire O2's, DX to z6 wire harness conversion, OBD0 to OBD1 Jumper supplied by JKOBD, all soldered in so you only have to pin in the new MPFI wires at the ECU plug
De-pin 4 pins, add 4 pins. Plug in the rest of the connectors.
DONE
The only way to go, you won't even recognize the dirty *** DX harness you pulled out of your car when you get it back, nicely taped, clean, ready to plug right into the Z6 head. You'll love it.
Old Mar 28, 2005 | 07:36 PM
madswapper's Avatar
Default Re: D16Z6 CRX SWAP(wiring harness) (NikoZai)
I have talked to rywire. I was trying to save some cash. I think you are correct about the cleaness, but my rex is down and I am dreading the shipping time and the 300$. When I could just do it myself and pop the d16 right back in ASAP. I guess there is really no other option.
thanks Niko.
Old Mar 28, 2005 | 07:51 PM
riceisnicenv's Avatar
sure you could pop the d16 right back in but would it start? if you don't have the wiring done right it won't and you will be back to zero again. if you can't figure it out after searching H-T you probably should have rywire help you out with the wiring. goodluck
memorybox
Jul 4, 2006 10:06 AM
grrrrrr4me
Mar 29, 2005 08:26 PM
Mr.Death
Sep 15, 2004 01:20 PM
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
