So will these disc brakes for the rear swap right in?
Old Mar 28, 2005 | 12:38 PM
whole9's Avatar
Default So will these disc brakes for the rear swap right in?
They will be going into my 91 si hatch. or do I need diff LCA?
Old Mar 28, 2005 | 01:02 PM
dr_latino999's Avatar
Default Re: So will these disc brakes for the rear swap right in? (whole9)
They should work, unless they are 4x114.5 which I can't tell by eye.....But I can see that they say DA so you are fine to go.
You can use the stock LCA.
Old Mar 28, 2005 | 01:38 PM
whole9's Avatar
Default Re: So will these disc brakes for the rear swap right in? (dr_latino999)
Awesomes
Old Mar 28, 2005 | 07:47 PM
Ef88Lsvtec's Avatar
That is so Weird I have a 88 STD and i put on GSR Rear disc brakes, and im still keeping my LCA but the TOE is way off. I changed the Trailing arms and left the LCA they way they are. Its weird i know that in the 88 Ef's STD or HF CRX its different in the back suspension then the 89-91 ef's. Anyone on here has an 88 ef STD or HF CRX that has put on rear disc with no probs?
Old Mar 28, 2005 | 07:55 PM
eda6's Avatar
Default Re: So will these disc brakes for the rear swap right in? (Ef88Lsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef88Lsvtec &raquo;</TD></TR><TR><TD CLASS="quote">That is so Weird I have a 88 STD and i put on GSR Rear disc brakes, and im still keeping my LCA but the TOE is way off. I changed the Trailing arms and left the LCA they way they are. Its weird i know that in the 88 Ef's STD or HF CRX its different in the back suspension then the 89-91 ef's. Anyone on here has an 88 ef STD or HF CRX that has put on rear disc with no probs?</TD></TR></TABLE>
Use the std compensator arms and the toe problems can be corrected.
Old Mar 28, 2005 | 08:42 PM
Riceburner247's Avatar
Default Re: So will these disc brakes for the rear swap right in? (eda6)
^ Ditto.
Old Mar 28, 2005 | 09:06 PM
whole9's Avatar
Default Re: So will these disc brakes for the rear swap right in? (Riceburner247)
Will I have an issue with toe?
Old Mar 28, 2005 | 09:22 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whole9 &raquo;</TD></TR><TR><TD CLASS="quote">Will I have an issue with toe? </TD></TR></TABLE>
use your existing control arms and you'll be fine.
Old Mar 28, 2005 | 09:58 PM
whole9's Avatar
thx ill let you know how it goes
Old Mar 28, 2005 | 10:29 PM
PURPLETERROR aka BIGMATT's Avatar
Those will work fine, better throw on some new rotors and pads while you are at it.
Old Mar 29, 2005 | 12:09 AM
Ef88Lsvtec's Avatar
Use the std compensator arms and the toe problems can be corrected??????
Modified by Ef88Lsvtec at 9:35 AM 3/29/2005
Old Mar 29, 2005 | 03:07 PM
Ef88Lsvtec's Avatar
compensator arms?????? Anyone???
Old Mar 29, 2005 | 04:06 PM
mrtoastyjr's Avatar
Default Re: (Ef88Lsvtec)
yes the arm that is at the oppsite end of the trailing arm than the rotor itself. the one from the DA is too long and it can onlt be adjusted so far. i used my stock arms from my 88 rex and they cam out perfect
Old Mar 29, 2005 | 06:53 PM
Ef88Lsvtec's Avatar
Default Re: (mrtoastyjr)
you have an si i said anyone with a 88 CRX HF or 88 STD Hatchback
Old Apr 1, 2005 | 05:45 AM
TurboCoop's Avatar
Make sure you have the brake lines form an integra. I had to order the lines from NAPA, and then I had to order banjo bolts for them from Honda. But that was going into an EK, so yours might be different.
Old Apr 1, 2005 | 05:55 AM
mike-y's Avatar
as said above, use your civic arms, and the trailing arm will bolt right up. The compensator arm is the little arm that bolts up to the front of the trailing arm, ahead of the rear wheel (where toe adjustments are made).
aside from getting new rotors, check the big trailing arm bushing. chances are, it needs to be replaced.
happy!
Mar 3, 2005 07:03 PM
Coletrain
Jan 31, 2005 04:15 AM
CRX SiR T
Jul 1, 2003 12:19 PM
DevineGSR
Jun 8, 2001 08:33 AM
elusiveracing7
Apr 29, 2001 04:41 PM
