Flywheel Question
Old Mar 28, 2005 | 12:26 PM
kazenokoe's Avatar
Default Flywheel Question
I found a Clutchmasters Aluminum and Steel Flywheel. It is a 7 lbs wheel. It wasn't used and has light oxidation surface rust. It is designed for a D series. Will this fit like OEM, Can i just scotch scuff the srface rust off. Will i need to do anything special to get it to work?
Old Mar 28, 2005 | 01:04 PM
kazenokoe's Avatar
Default Re: Flywheel Question (kazenokoe)
anyone
Old Mar 28, 2005 | 01:22 PM
delslo93's Avatar
Yeah it will fit like OEM, just lighter obviously. Just scuff up the flywheel getting all the rust off and making sure not to get any grease or oil on it. Put that pig in there and it should work fine.
Fnix
Transmission & Drivetrain
Sep 29, 2010 08:37 AM
brent_si
Mar 13, 2008 03:43 PM
mtownek9
18
Oct 23, 2007 08:48 AM
ge_itr
Jan 17, 2007 08:44 AM
iperez
Nov 18, 2004 12:51 PM
