whats the difference between 88 si tranny and 89 si tranny???
Old Mar 28, 2005 | 11:30 AM
phoQ's Avatar
Default whats the difference between 88 si tranny and 89 si tranny???
can anyone help me out i have an 89 si but my 2nd gear is grinding when i downshift, so far the only replacement tranny i have found is an 88 si tranny. are parts just as available for the 88 as they are for the 89-91. is it a downgrade. i eventually want to get a lightweight fywheel and crunk clutch. what do you think?
Old Mar 28, 2005 | 11:35 AM
EP3_05's Avatar
Default Re: whats the difference between 88 si tranny and 89 si tranny??? (phoQ)
The number of splines on the input shaft are different between the 88 and 89. Otherwise they are the same.
Old Mar 28, 2005 | 11:39 AM
user 98292739's Avatar
you have to buy a new 88 clutch.flywheel. and i think the clutch is lil bit smaller on the 88...but other then that they should bolt right up
Old Mar 28, 2005 | 11:57 AM
dr_latino999's Avatar
Default Re: (LoCoReX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCoReX &raquo;</TD></TR><TR><TD CLASS="quote">you have to buy a new 88 clutch.flywheel. and i think the clutch is lil bit smaller on the 88...but other then that they should bolt right up</TD></TR></TABLE> The clutch is the same size in 1988 and 1989, 200mm.
Old Mar 28, 2005 | 12:06 PM
phoQ's Avatar
so performance wize they are the same, do you think i could find a lightweight fylwheel and good clutch for an 88 si tranny??
Old Mar 28, 2005 | 12:07 PM
EP3_05's Avatar
Default Re: (phoQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoQ &raquo;</TD></TR><TR><TD CLASS="quote">so performance wize they are the same, do you think i could find a lightweight fylwheel and good clutch for an 88 si tranny??</TD></TR></TABLE>
Yes they are available.
Old Mar 28, 2005 | 12:09 PM
Default Re: (phoQ)
It is just harder to find, hence forth why my 88 transmission will bite the dust for an 89 in the coming weeks.
Old Mar 28, 2005 | 12:24 PM
but wait then the 90-91 have bigger disc?
Old Mar 28, 2005 | 12:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCoReX &raquo;</TD></TR><TR><TD CLASS="quote">but wait then the 90-91 have bigger disc?</TD></TR></TABLE>Correct, 212mm.
Old Mar 28, 2005 | 03:55 PM
phoQ's Avatar
so should I jusat wait to fond a 89 and up tranny? what about having my 89 unit rebuilt how much does that usually run?
Old Mar 31, 2005 | 08:23 AM
phoQ's Avatar
oh yeah what about axles from my 89 will they work with the 88 tranny??
Old Mar 31, 2005 | 09:41 AM
messeduprex's Avatar
Default Re: (phoQ)
yes
Old Mar 31, 2005 | 09:45 AM
phoQ's Avatar
thanks
like corollas?
peep mine
http://www.msnusers.com/corollaandcrx
stivic
Nov 22, 2006 10:23 PM
EF_9
May 24, 2005 10:36 PM
user 98292739
26
Oct 20, 2004 12:40 AM
LoooseGSR
10
Nov 27, 2003 08:50 PM
88EF
12
Apr 9, 2003 03:28 PM
