198,000 d16a6 turbo?
Old Mar 28, 2005 | 11:19 AM
mawkiemarc's Avatar
Default 198,000 d16a6 turbo?
ive got a 90 hatch d16a6 with 198,000 miles and was wondering if there would be any problem slapping a turbo on the lil beast? are there many pros than cons or the other way around? if you say yes, what kinda turbo do yall recommend?
thanks
Old Mar 28, 2005 | 11:21 AM
AbitAvenger's Avatar
search
http://www.homemadeturbo.com
Old Mar 28, 2005 | 11:29 AM
black88si's Avatar
Default Re: (AbitAvenger)
lol, you can put a turbo on any engine. Just need to build your engine for it. New pistons/rods would be a good idea at 200k. Upgrading your valvetrain would also be a good idea. You cant really safely just slap a turbo on a car lol.
Old Mar 28, 2005 | 11:58 AM
dr_latino999's Avatar
Do to further investigation - leaving the browser open on homemadeturbo as it tried to load for about 10 minutes - I have come to the conclusion it is up, but hanging on for a dear life. Conclusion, me.
Old Mar 28, 2005 | 12:00 PM
1990civicsiguye's Avatar
that is funny a flame on the flame .... wtg dr
Old Mar 28, 2005 | 12:41 PM
mawkiemarc's Avatar
Default Re: (black88si)
well yeah this is tru my brother. do you think i should go with some EAGLE rods and pistons and a SKUNK2 valvetrain?
Old Mar 28, 2005 | 12:44 PM
EP3_05's Avatar
Default Re: (mawkiemarc)
Eagle rods, CP or Wiseco pistons, new gaskets, ARP head studs. Leave the valvetrain alone unless you want to raise the rev limit or want to run a turbo cam. Basically completely rebuild the bottom end with forged components and you will have a good base to start running a turbo setup.
Old Mar 28, 2005 | 12:52 PM
mawkiemarc's Avatar
what does the bottom end consist of?
Old Mar 28, 2005 | 12:55 PM
EP3_05's Avatar
Bottom end=
Engine block
Crankshaft
Pistons
Rods
Oil Pan
Oil pump
etc.
Old Mar 28, 2005 | 12:56 PM
mawkiemarc's Avatar
Default Re: (91civic)
so your also saying not to upgrade the Valvetrain? why im jw bc i found this great deal on a SKUNK 2 system...
Old Mar 28, 2005 | 01:00 PM
EP3_05's Avatar
It depends on the cam. Some cams will actually not work well with a turbo system. You will want to run a cam specifically meant for turbo applications.
Old Mar 28, 2005 | 01:09 PM
mawkiemarc's Avatar
oh i see what you mean, thanks and good lookin
Old Mar 28, 2005 | 02:03 PM
hotimportcrx's Avatar
Default Re:
with 198,000 miles you should be lucky your engine still takes gas let alone a turbo.....thats high miles i would build it a little or get another a6 for like 500$ and put a t3 on it with like 7psi....and you should be fine without building internals on a low mile a6
Old Mar 28, 2005 | 02:11 PM
black88si's Avatar
Default Re: Re: (HondaDelsol17)
i say build the valvetrain specifically for a turbo. get a turbo cam, and some nice springs. Might as well get a p&p while your in there. all just safeguards you. I know that I always want to take my car up into 8500. with a built motor and a decent turbo you could safely go that high, which you will probly want to. Skunk2 valve springs and retainers are pretty decent. Definately go with a cam specifically designed for a turbo. Call all the manufacturers and talk to them about your car and your application.
Remember this. Running a turbo safely is all about engine/fuel managment. Get a good engine managment system. It will help save your butt.
Old Mar 28, 2005 | 02:51 PM
2kTeg's Avatar
Default Re: Re: (black88si)
If it doesn't smoke yet i would say go for it, buy a nice fuel management like a zdyne and she will take boost for awhile and then when it finally goes just buy another single cam longblock for dirt cheap.... dseries motors are like ***** they are fun to pass around tell the get clapped out
Old Mar 28, 2005 | 06:25 PM
mawkiemarc's Avatar
Default Re: Re: (2kTeg)
ay man, when im done setin up with what i want in my single, we'll see who gets passed around aight...?
khaledbuiltEF
Sep 25, 2010 09:35 PM
b16vt3c
Feb 3, 2010 07:45 PM
rylflsh1806
May 19, 2009 02:33 PM
SandFanatic
Dec 5, 2007 10:55 AM
zachattack54
Jan 30, 2007 04:00 PM
