50 series tire too big?
Old Mar 28, 2005 | 08:04 AM
bigkshep's Avatar
Default 50 series tire too big?
Do you guys think a 50 series tire is too big for a 15 slipstream? I know someone selling them and Im thinkin about gettin them. I would use these tires but when they need new ones i would get 45. If anyone has 50 series on slips can you post them. Thanks
Old Mar 28, 2005 | 08:12 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 50 series tire too big? (bigkshep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigkshep &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys think a 50 series tire is too big for a 15 slipstream?</TD></TR></TABLE>
That depends on what size tires your car normally takes, and what tire size you're considering. As a general rule, you want to keep the outer diameter of the tire size about the same as stock, and you don't want to use tires that are so wide that they will rub on your fender well liners. It has nothing to do with which wheel you're using.
What is the stock tire size on your car?
Old Mar 28, 2005 | 12:22 PM
Asselin's Avatar
50 series are perfect.
45 would throw off ur speedo quite a bit probably, but yah it would help if we knew what kind of car you had.
Here's a pic of my 195/50/15 Toyo T1-S I just got.
Old Mar 28, 2005 | 12:49 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Asselin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asselin &raquo;</TD></TR><TR><TD CLASS="quote">50 series are perfect.
45 would throw off ur speedo quite a bit probably</TD></TR></TABLE>
You can't know whether either of those statements are true, unless you know the stock tire size and what kind of tread width we're talking about. (For example, on most of our cars, a 315/50-15 would NOT be so good, but a 215/45-16 might not throw off the speedo at all.)
Old Mar 29, 2005 | 10:36 PM
Import13alla's Avatar
Default Re: (nsxtasy)
http://www.miata.net/garage/tirecalc.html
use it and abuse it!
Old Mar 30, 2005 | 07:28 AM
Mike_C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You can't know whether either of those statements are true, unless you know the stock tire size and what kind of tread width we're talking about. (For example, on most of our cars, a 315/50-15 would NOT be so good, but a 215/45-16 might not throw off the speedo at all.)</TD></TR></TABLE>
the 50 is a percentage of the width of the tire. check the faq!
Old Mar 30, 2005 | 05:35 PM
NaVamous's Avatar
I got 205/50 on 15" Si wheels. The car is a 98 EX. Compared to tires I had before, the ride feels more cushioned when I hit bumps on the road.
Old Mar 30, 2005 | 07:00 PM
8krdline's Avatar
Default Re: (NaVamous)
i have 50s on my slips
Old Mar 30, 2005 | 07:33 PM
Mike_C's Avatar
Default Re: (8krdline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8krdline &raquo;</TD></TR><TR><TD CLASS="quote">i have 50s on my slips </TD></TR></TABLE>
50s means nothing!!! a 120/50 is a far thinner sidewall than a 300/50.
Old Mar 31, 2005 | 05:32 AM
8krdline's Avatar
Default Re: (Mike C)
i know that, but what are the chances that he's gonna get something other than 195 or 205.
Old Mar 31, 2005 | 05:34 AM
Mike_C's Avatar
but even those are different. a 195/50 should fit no problem. my 205/50s rub a little at full lock or when going over speedbumps.
Old Mar 31, 2005 | 05:17 PM
LShatchie's Avatar
i love my 50 series on my slips, they offer such a comfortable ride and hug the road nicely (falkens)
Old Apr 1, 2005 | 06:27 AM
jdm123's Avatar
Default Re: (civichatch6989)
i have 205/50/15 yoko's on my slips witha 2" drop and i get no rubbage. i did when i had 55's on though
edit- ^ if that is what your worryed about
Old Apr 1, 2005 | 03:15 PM
GetawayInMoscow's Avatar
Default Re: (jdm123)
205/50/15 is TOO BIG unless your wheels is ATLEAST 7" wide
Alternatively, you can run 195/50/15s
Old Apr 1, 2005 | 03:18 PM
Mike_C's Avatar
Default Re: (GetawayinMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayinMoscow &raquo;</TD></TR><TR><TD CLASS="quote">205/50/15 is TOO BIG unless your wheels is ATLEAST 7" wide</TD></TR></TABLE>
negative, 205/50/15 can be used on 5.5-7.5 wheels.
Old Apr 2, 2005 | 09:24 AM
jaydmcrx's Avatar
205/50/15 on my crx kuhmo mx's Grip really well. No problems what so ever.
vietxdragon
Apr 2, 2008 08:50 PM
HBADGE
Mar 23, 2006 01:03 AM
gocivicgo
Aug 28, 2003 01:21 PM
gribbs
Jan 29, 2003 08:40 AM
Mr. Softee
Dec 26, 2001 05:03 PM
