High revving LSVTECs, chime in!
Old Mar 28, 2005 | 06:05 AM
LSVTEC 91 Civic's Avatar
Banned
Default High revving LSVTECs, chime in!
I'm curious to know how high you all take your LSVTECs, what mods you have, and how your bottom end is built.
I'm running a balanced LS Crank, with ARP rod bolts.. I keep mine at 8100 (rev limit), but I usually shift around 7900.
Old Mar 28, 2005 | 06:39 AM
tcr03's Avatar
8200. just a new bottom end. new ls rods and gsr pistons.
Old Mar 28, 2005 | 07:19 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: High revving LSVTECs, chime in! (LSVTEC 91 Civic)
Mine is almost finished, I don't think I'll be revving over 8500 ont he track, and daily, MAYBE 8k. The bottom end is freshened with stock LS rods, JDM ITR pistons and ARP rod bolts...everything balanced. I just don't want to push my luck...
-Chris
Old Mar 28, 2005 | 07:28 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: High revving LSVTECs, chime in! (DAantagonist)
stock ls bottom, ctr pistons, new bearings and rod bolts... goin to 9k
Old Mar 28, 2005 | 08:49 AM
myke5505's Avatar
Default Re: High revving LSVTECs, chime in! (turbofienD 04)
bolt ons, stock head, stock bottom, arp rod bolts, 8200 all day
Old Mar 28, 2005 | 09:48 AM
goforbroke's Avatar
MEAT PATTY
I dont' have a lsvtec but I'm going to be building one over the summer. I noticed you said high revving lsvtec but you and everyone included isn't revving the **** out of theirs considering 8000rpm is where everyone revs them too.....
Old Mar 28, 2005 | 10:25 AM
JOHN WAYNE's Avatar
Default Re: High revving LSVTECs, chime in! (goforbroke)
9500 - not often
- crower rods
- cp pistons
- golden eagle 3 main girdle
- golden eagle block guard
Old Mar 28, 2005 | 10:31 AM
japspecnegro's Avatar
Default Re: High revving LSVTECs, chime in! (JOHN WAYNE)
i know this is a post thread and not a question thread but what should i rev it to
OEM B16 Pistons w/ rings
Golden Eagle Bolck Guard
Golden Eagle Girdle Kit
ARP Rod Bolts
Old Mar 28, 2005 | 10:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOHN WAYNE &raquo;</TD></TR><TR><TD CLASS="quote">9500 - not often
- crower rods
- cp pistons
- golden eagle block guard</TD></TR></TABLE>
the difference is though you spent some serious money on the bottom end. I don't think many of us did that lol. Frankly, I'm scared to rev much higher than that even with my ARP rod bolts.
-Chris
Old Mar 28, 2005 | 11:02 AM
AlLMoToRvOtEr's Avatar
From what I have heard LS cranks are only supposed to make power up to about 8800. But from expierence I have shifted multiple Ls/Vtec's between 9 and 9,500K
So pretty much shift up until it stops making power.
Old Mar 28, 2005 | 11:45 AM
JOHN WAYNE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris</TD></TR></TABLE>
yes, well i suppose thats true haha.
personally i wouldnt feel safe revving past 8000 on stock internals. my power peaks around 8000 rpm anyway...but it doesnt drop off drastically so revving a little bit towards 9000 carries me higher into the range after the shift.
Old Mar 28, 2005 | 11:51 AM
personally i wouldnt feel safe revving past 8000 on stock internals. my power peaks around 8000 rpm anyway...but it doesnt drop off drastically so revving a little bit towards 9000 carries me higher into the range after the shift.</TD></TR></TABLE>
My CTR cams should make power past 8K, I would really like to be able to, we'll see how it does after tuning...maybe I'll get to shift a little higher. REMEMBER, the object is to NOT blow the motor lol! Seriously, I'll prolly keep my shifts less than 8k unless I'm on the track...
Old Mar 28, 2005 | 12:49 PM
AllMTRWH0R3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbofienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">stock ls bottom, ctr pistons, new bearings and rod bolts... goin to 9k</TD></TR></TABLE>
Had the same setup, I just used gsr bearings instead ( that's where I think the problem lays in "true stock LS/vtec's" ) went to 9200 RPM's.
If your road race then the arp bolts are good, but you dont really need them if you drag. Remember tuning is key to everything aswell.
Old Mar 28, 2005 | 01:27 PM
DA9Dave's Avatar
I am too scared to rev any higher than 7500 (rev limiter 7600rpm), my set up is stock LS bottom, LS pistons, ARP bolts
Old Mar 28, 2005 | 01:38 PM
Default Re: (DA9Dave)
SADLY, I don't know of like a universal rev limit for them of any point. I'm just going to keep it conservative until I get it tuned and let my tuner tell me what I can rev to and not bomb it lol.
-Chris
Old Mar 28, 2005 | 01:51 PM
athoughts's Avatar
Default Re: (DAantagonist)
drive it like you stole it
Old Mar 28, 2005 | 02:15 PM
justBLZE's Avatar
Chopper 2 Hopper
Rev until you stop making power.
I don't know too many cams or motor setups that actually make power beyond 9K RPM.
I plan on revving mine till 8500, using BC stage 4 cams, but dyno will determine..
Old Mar 28, 2005 | 02:20 PM
Rusty Shackleferd's Avatar
Default Re: High revving LSVTECs, chime in! (tommy69)
Check video in my sig, stock pr4 rods w/arp bolts, dont be scared
Modified by Rusty Shackleferd at 5:00 PM 3/28/2005
Old Mar 28, 2005 | 02:44 PM
Default Re: High revving LSVTECs, chime in! (Rusty Shackleferd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rusty Shackleferd &raquo;</TD></TR><TR><TD CLASS="quote">Check video in my sig, stock pr4 rods w/arp bolts, dont be scared
Old Mar 28, 2005 | 03:42 PM
Hybrid96EK's Avatar
Default Re: High revving LSVTECs, chime in! (AlLMoToRvOtEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlLMoToRvOtEr &raquo;</TD></TR><TR><TD CLASS="quote">From what I have heard LS cranks are only supposed to make power up to about 8800. But from expierence I have shifted multiple Ls/Vtec's between 9 and 9,500K
So pretty much shift up until it stops making power.</TD></TR></TABLE>
Crank isn't what dictates where an engine peaks. Headflow and r/s ratio do. I serioulsy doubt you drove any Ls/Vtec's that "Peaked" or stopped making power at no 9 or 9,500rpm. Unless you had some REAL serious cams. Did you dyno them to see they quit making power there or did the *** dyno tell you?
Old Mar 28, 2005 | 06:08 PM
Banned
Damn... thats a lot of RPM. I'm just concerned with spinning another rod bearing.
Old Mar 28, 2005 | 06:23 PM
reactiondc2's Avatar
i ran shotpeened rods,pr3 pistons,arp bolts,acl bearings,polished crank,gsr oil and water pumps,itr head,rocket springs,wicked stage 2 cams=spun it to 9500 sometimes but mostly tried to shift by 9200..ran strong for ten thousand miles till i sold it
Old Mar 28, 2005 | 09:53 PM
speedy1's Avatar
.40 over bore weisco 12.5:1 comp! milled GS-R head street strip port and polish. 3 angle vavlejob. Crane 3 cams. rev dual valvespring with ti retainers. Black nitrate coated flat top valves. Oh all on stock rods and i turn 9.2k all day every day! no problems here! YAY
Old Mar 29, 2005 | 05:05 AM
ea_hatch's Avatar
stock rods, arp rod bolts and head studs, new oem bearings. p30 pistons, i usually shift around 8500 but i took her to 9300 the other night on accident
Old Mar 29, 2005 | 05:42 AM
Default Re: (speedy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedy1 &raquo;</TD></TR><TR><TD CLASS="quote">.40 over bore weisco 12.5:1 comp! milled GS-R head street strip port and polish. 3 angle vavlejob. Crane 3 cams. rev dual valvespring with ti retainers. Black nitrate coated flat top valves. Oh all on stock rods and i turn 9.2k all day every day! no problems here! YAY</TD></TR></TABLE>
oh god, sounds like someone was bangin the hell outta vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 &raquo;</TD></TR><TR><TD CLASS="quote">i ran shotpeened rods,pr3 pistons,arp bolts,acl bearings,polished crank,gsr oil and water pumps,itr head,rocket springs,wicked stage 2 cams=spun it to 9500 sometimes but mostly tried to shift by 9200..ran strong for ten thousand miles till i sold it </TD></TR></TABLE>
not bad not bad at all. i wanna be shiftin around there also
