AXLE QUESTION
Hi!
I have drivers side axle from my last car which was 1994 Civic DX hatch...
My question is: can I use that axle on my 96 DX coupe (D16Y7)? will it fit? Is it the same length?
So if anyone knows, I would appreciate the help... I searched but found nothing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr »</TD></TR><TR><TD CLASS="quote">d series are the same as long as you stay manuel to manuel or auto to auto to fully state it</TD></TR></TABLE>
Actually, manual and auto axles ARE interchangeable.
Just going by what the Honda factory parts diagrams tell me...first is manual tranny, second is auto:
http://slhondaparts.com/browse...81%29
ive heard of other people trying this - on both d and b series didnt work - stick auto to auto - manuel to manuel to be on the safe side of things also mind the differences of abs non abs - etc- those things will make a differance always
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr »</TD></TR><TR><TD CLASS="quote">ive heard of other people trying this - on both d and b series didnt work - stick auto to auto - manuel to manuel to be on the safe side of things also mind the differences of abs non abs - etc- those things will make a differance always </TD></TR></TABLE>
HUH???????
So it means if I have an axle from NON-ABS car, it won't fit the ABS car...
Cos my 94 hatch didn't have ABS... and my 96 coupe has ABS... now I am worried cos the tools are ready and I am going to disassemble the whole thing so better hurry with some answers
HUH???????
axels from cars with abs will have abs rings- as for putting non abs axels into an abs car i think that cannot be done- but as for abs axels into a non abs car i have not a clue - some one who knows please answer
I think that CV joint is the one with the ABS ring... cos ABS sensor is on the knuckle and the only thing from axle that is close to the knuckle is CV joint...
Hmmm... I will check that...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi »</TD></TR><TR><TD CLASS="quote">I think that CV joint is the one with the ABS ring... cos ABS sensor is on the knuckle and the only thing from axle that is close to the knuckle is CV joint...
Hmmm... I will check that...</TD></TR></TABLE>
I think you are right, it's not that it doesn't fit it's just that ABS won't function without the correct axle.
So is it the driveshaft itself or just the CV joint problem...
If I use the driveshaft and replace the CV joint with the ABS one, I think that might work...
Cos I have mint condition CV joints at home for my coupe (with ABS) and I have one shaft (without CV joints) from my previous car which was non-ABS
yes i read some where about some one with h22 swap who had massive shaking - he forgot to remove the abs rings from his axels- as long as they are taken off they made it sound as if it would be fine - but since he used them with rings on the axels went bad some how
1 sLoW hAtCh
Feb 18, 2007 07:37 PM
DJNauTicz
10
Sep 7, 2005 07:03 PM
