obd conversion dizzy wiring for f22
im swapping from auto to 5spd this friday and i need help with an obd2a-obd1 conversion so i can use my pob ecu.
i have the obd2a->obd1 harness, an obd1 dizzy with external coil, and the pob ecu. I have a 97 accord lx with external coil as well. ill be swapping to obd1 cause one, i got the ecu already, two i might need to use hondata or some other fuel management for coming boost.
so i need help on how to wire up the sensor from the block to the dizzy or if i need to at all. ive searched all the archived threads but got quite confused with all the h22 dizzy wiring threads. will i need to wire up anything else other than that sensor? will the obd1 dizzy plug right into my current obd2 dizzy plug on the engine harness? theyre both external coil, im assuming the coils are interchangeable.
will i have any idle problems or need to mess with the injectors, fuel pressure, etc.... these may be from the 6th gen obd conversion and the h22. im ridiculously confused at this point. need help asap. thanks in advance.
Fezzie
Aug 31, 2006 05:40 AM
97dxnut
Aug 4, 2003 11:46 PM
