Vibrating/rattling shifter? I think i might have a solution!
Old Mar 27, 2005 | 08:59 PM
erikiksaz1's Avatar
Default Vibrating/rattling shifter? I think i might have a solution!
My shifter used to vibrate at anything over 4000 RPMs, whether or not I was in a gear. It was so bad that it even caused my shift **** to vibrate. Thinking that the shifter was rubbing the exhaust, I brought it to a muffler shop and had the exhaust dropped about a quarter of an inch. Even after the drop, I still had the damned vibrating. I went under the car today and finally took a look at the shift linkage.
The lowest part of the shifter, where the shift linkage bolt passes through, seemed to be the problem. On my stock ITR shifter, there were about 6 metal washers sandwiched between the shift linkage and the shifter. I went to Home Depot and replaced those metal washers with some thick teflon spacers. Tightened everything down, and now there are no longer any vibrations!
Old Mar 28, 2005 | 11:18 AM
SleepRdc2's Avatar
Default Re: Vibrating/rattling shifter? I think i might have a solution! (erikiksaz1)
i have the same problem, i had to take off my exhaust shield and it stopped the rubbing but the shifter itself rattles above 4k. i used a bushing from a parts store to fix the gap between the linkage and the shifter but it still rattles a bit, got any other ideas to fix it?
Old Mar 28, 2005 | 11:37 AM
erikiksaz1's Avatar
Default Re: Vibrating/rattling shifter? I think i might have a solution! (SleepRdc2)
Just make sure that the shifter is *very* snug between the shift linkage collar thing. In addition to the teflon spacers, i used these rubber coated metal washers.
When you're underneath the car, have somebody move the shifter left and right quickly. If you can hear some sort of loose jingle jangle, then you've got more washers to add!
Old Mar 28, 2005 | 01:51 PM
SleepRdc2's Avatar
i like using the bushings because of one less thing to rattle. i have a washer on each side of the bushing so it wont wear out so fast when rubbing occurs on the shifter and linkage. i guess i have to re-cut some new ones.
Axle Raynes
Jul 15, 2009 06:54 AM
twentyhurtz
Jun 19, 2009 03:53 PM
dr_latino999
22
Jan 15, 2007 04:14 AM
.Ryan
Jul 26, 2004 06:16 PM
charjacq
Apr 27, 2002 12:32 PM
