Rear Disk Breaks
I got a 95 VX with almost complete GSR conversion (interior, suspension, motor, trans) I have a whole list of stuff that was pulled from a GSR. If you want it let me know. Hope it helps.
Guest
Posts: n/a
To do the entire swap you need:
-Trailing arms (with entire brake assembly intact) from a 99-00 Civic Si, 93-97 Del Sol w/rear disc, or 94-00 Integra
-40/40 Proportioning valve
-Civic Si handbrake cables
-Rear brake lines for disc. Since you're doing the job, you might as well just get the stainless lines for 99-00 Civic
Since you have an EX, you should be fine with the OEM ms and booster
