antifreeze in cylinder 4
Old Mar 27, 2005 | 06:46 PM
Boost Lee's Avatar
Default antifreeze in cylinder 4
i just put a 94ls motor into my 99ls. it started and white smoke starts to come out. smells like antifreeze, so i check the plugs and cylinder 4 is filled w/ antifreeze. the headgasket is fine so thats out of the question. one of my friends think that its the intake manifold gasket. could antifreeze get in that cylinder if the gasket is blown?
Old Mar 27, 2005 | 07:26 PM
GsR-Freak's Avatar
Default Re: antifreeze in cylinder 4 (Boost Lee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost Lee &raquo;</TD></TR><TR><TD CLASS="quote">i just put a 94ls motor into my 99ls. it started and white smoke starts to come out. smells like antifreeze, so i check the plugs and cylinder 4 is filled w/ antifreeze. the headgasket is fine so thats out of the question. one of my friends think that its the intake manifold gasket. could antifreeze get in that cylinder if the gasket is blown?
wtf your friends are smoking , IM's gasket leaks then leak sympton should be at the IM not inside Cyclinder4 for whatever reason.
i dont know why you said HEADER GASKET IS FINE SO THAT'S OUT OF THE QUESTION. hgasket leak doesn't necessary to have leak going out of the gasket.
if coolants are in cyclinder 4 when checking spark that means coolants had been in cyclinder 4 combustion chamber. if coolants able to go in cyclinder 4, YOU GOT BAD GASKET INSTALLATION?
think about it
Old Mar 27, 2005 | 07:27 PM
GsR-Freak's Avatar
Default Re: antifreeze in cylinder 4 (GsR-Freak)
head gasket, not HEADER GASKET* SORRY FOR TYPO
Old Mar 27, 2005 | 07:42 PM
Boost Lee's Avatar
i say the head gasket is fine because i just replaced it. i've replaced a head gasket 3 times before and i always use a helms for reference. maybe the head or block is warped?
heres the scenario:
im filling the radiator w/ antifreeze, w/ the spark plug out of cyc.4 i start to see antifreeze going in. not flooding in but slowly.
Old Mar 27, 2005 | 07:53 PM
mr.beeks's Avatar
LOL
it is to possible to have a crack in the intake manifold or the
the head itself so have that double check.....
Old Mar 27, 2005 | 07:58 PM
Ekay Jay's Avatar
Just a thought but cracked block maybe? Did u have enought antifreeze in it when it was cold?
Old Mar 27, 2005 | 08:05 PM
Boost Lee's Avatar
Default Re: antifreeze in cylinder 4 (JdM DA InTeGrA)
yeah, im thinking cracked/warped block or head. but when my friends were telling me it might be the im gasket, that i put it on wrong or its blown i was like wtf? i used my 99 im on the 94 block, isnt it a straight swap?
Old Mar 27, 2005 | 09:42 PM
4U2NV's Avatar
It's could be a cracked sleeve or something... I'd pull the head and check all the sleeves...
Old Mar 28, 2005 | 08:24 AM
RuskeR's Avatar
Worse case senairo is a cracked block. Your going to have to pull everything to check. Hope it works out for you
Old Mar 28, 2005 | 05:41 PM
Boost Lee's Avatar
Default Re: (RuskeR)
hey,
i havent had time to work on my car or even check things out because of work and other things, but i just wanted to know if there were any differences (gasket,holes lining up) with a 94 obd1 to a 99 obd2 intake mani.? my friend who sold me the motor swears that is the problem.
Old Mar 28, 2005 | 08:04 PM
Boost Lee's Avatar
Default Re: (Boost Lee)
anyone?
Old Mar 29, 2005 | 02:23 AM
GsR-Freak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost Lee &raquo;</TD></TR><TR><TD CLASS="quote">i say the head gasket is fine because i just replaced it. i've replaced a head gasket 3 times before and i always use a helms for reference. maybe the head or block is warped?
heres the scenario:
im filling the radiator w/ antifreeze, w/ the spark plug out of cyc.4 i start to see antifreeze going in. not flooding in but slowly.</TD></TR></TABLE>
whatever it is....you got internal bleeding. either cracked, badgasket installation, block or head gasket's mounting surface is warped, somewhere at C-4
well good luck man...but only the only way to know is to open it up when u got time...sound like it's warped
Old Mar 29, 2005 | 03:03 AM
non-VTEC's Avatar
it could be the intake manifold gasket......there is that coolant passage right beside the #4 intake runner that could be leaking into the cylinder.
you might want to bring the head into a machine shop to see if the surface is flat. maybe pressure test it as well...
Old Mar 29, 2005 | 06:39 PM
Boost Lee's Avatar
Default Re: (non-VTEC)
got back from work and decided to do a comp. test (just in case) i got 195 across the board. so thats a good thing. thanks for the advice...
shm91
25
Dec 12, 2013 10:33 PM
EF Driver
Jun 12, 2007 12:16 AM
prostreetonline
Jan 19, 2006 09:46 AM
[HrZn]4life
May 19, 2005 09:12 AM
