98 accord will jumpstart but not start on its own!
Old Mar 27, 2005 | 06:41 PM
soggychips's Avatar
Default 98 accord will jumpstart but not start on its own!
Hi everyone, new user but been reading the forums for a long time. Good stuff...
I have a 98 Accord 4-cyl, 130k miles that will not start. When i turn the key, it won't start. No sounds, no nothing. I've just replaced the alternator and battery and also tested them and they are fine. I can even jump start the car but it just will not start on its own after that. I don't get headlights or wipers when the car is off. I forgot to check after i jumped it.
Seems like there's enough juice to power the door and roof lights and clock when the car is off but when I try to start the car, all the electronics die. Since it can jump start, i'm not sure what the real problem could be. Anyone have any insight to this problem? I'm really confused. Thanks.
Old Mar 27, 2005 | 07:06 PM
Maxx PARANOiA's Avatar
Default Re: 98 accord will jumpstart but not start on its own! (soggychips)
Chances are you have a bad ground from the battery. My friend's car did this for a while, and we tried everything....and it turned out to be the ground wire....just make sure you've got a good connection and if not, then re-ground it and try again.
Old Mar 28, 2005 | 07:34 AM
Stew Pidasso's Avatar
Default Re: 98 accord will jumpstart but not start on its own! (Maxx PARANOiA)
Was this car under the ignition switch recall?
Old Mar 28, 2005 | 01:39 PM
Accord_Kid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxx PARANOiA &raquo;</TD></TR><TR><TD CLASS="quote">Chances are you have a bad ground from the battery. My friend's car did this for a while, and we tried everything....and it turned out to be the ground wire....just make sure you've got a good connection and if not, then re-ground it and try again.</TD></TR></TABLE>
Old Mar 28, 2005 | 06:52 PM
RedDC5's Avatar
Default Re: 98 accord will jumpstart but not start on its own! (Accord_Kid)
Sounds like an electrical problem to me.
Old Mar 28, 2005 | 09:09 PM
zumiez007's Avatar
Default Re: 98 accord will jumpstart but not start on its own! (4door_ridin)
may be the starter. gently tap it with a hammer. but double check the bat cables.
honeyhuckabee
Dec 1, 2015 10:59 AM
donboley
Jul 10, 2013 06:34 PM
evani01
May 13, 2013 08:31 AM
mistawho
Dec 14, 2005 07:44 AM
