Type R Spoiler
Hi i recently put on a type r spoiler and was wondering how should it fit. Shoudl it move around a little or be very tight. also i dont know the perfect spot so if anyone has pictures it would be very helpful thanks! oh any ideas to cover the extra holes would nice. thanks a lot.
It should be tight, but don't break anything. You'll know when it's right.
Extra holes? I'm assuming there was an aftermarket on there before?
Use body filler and new paint, or see a body shop and have them do it.
I've got the Type R spoiler too. Check below if you want.
wouldn't you need something from the other end of the hole to hold the body filler?? When i shave my side moldings, i glued little metal plates to the inside of the hole and filled the outside with bondo. is body filler the same as bondo?? you can also have it welded.
Kirk@SyndromeAuto
Nov 14, 2006 06:31 PM
