B16a bogging down..
Old Mar 27, 2005 | 05:29 PM
90ED9's Avatar
Default B16a bogging down..
My friend's 89 CRX Si with B16 swap is bogging down whenever it gets warm, or whenever it enters VTEC. We have swapped out plugs, wires, and injectors, and we are out of ideas. Was wondering if anyone has had a similar problem or has any suggestions of how to alleviate it.
Old Mar 27, 2005 | 05:34 PM
turboJDMeg6's Avatar
Default Re: B16a bogging down.. (90ED9)
i had the same problem but i just did a injector cleaning. free from work, and it worked like a charm, so my injectors were clogged but u said u replaced urs, maybe ur o2 wires are hooked up reverse? the common problem i had read on here
Old Mar 27, 2005 | 07:36 PM
90ED9's Avatar
Default Re: B16a bogging down.. (91b16ef9)
thanks man but the motor has been in the car for a while now, but we'll check that tomorrow.
Old Mar 28, 2005 | 12:39 PM
90ED9's Avatar
anybody else?
Old Mar 28, 2005 | 01:09 PM
N1ghtM0nkey's Avatar
Default Re: (90ED9)
Definately make sure your O2 sensors are hooked up to the correct pins on the ECU. There is more information in the FAQ pinned to the top of this forum.
Old Mar 28, 2005 | 08:57 PM
JSN_LQ's Avatar
bump for my homie
Old Mar 28, 2005 | 09:10 PM
thatbluecrx's Avatar
Default Re: (JSN_LQ)
i dont exactly know what kind of bog you are talking about, but it could be TPS related if its not o2
Old Mar 28, 2005 | 09:34 PM
90ED9's Avatar
ive swaped the tps with two of my friends (working) tps's, and it still bogs.. ive even switched the saturation box (just because i ran out of ideas) and still nothing
Old Mar 29, 2005 | 03:03 PM
Default Re: (90ED9)
did the car start a dpfi and get converted to mpfi? if so your tps wiring could be off, not the sensor itself
Old Mar 29, 2005 | 03:47 PM
tallguy's Avatar
this is probably not it but i know my car runs like crap if i don't use NGK's
Old Mar 29, 2005 | 06:47 PM
90ED9's Avatar
i just put NGK plugs and MSD wires, still bogs
Old Apr 4, 2005 | 08:41 PM
JSN_LQ's Avatar
my friend is in the process of moving and we were at the h-t meet and he has replaced the ignitor, the coil, rotor button, dizzy cap, and it is really goin downhill...im suprised we made back to montgomery from the atl h-t meet. but i guess ill let him give the details
Old Apr 8, 2005 | 09:12 AM
TrizzyDizzy's Avatar
bump it, i guess
Old Apr 17, 2005 | 04:45 PM
90ED9's Avatar
ahh, finally online again...but i think ive figured out the problemk, i have rust in my tank and also a couple of wires are coming loose on my injector clips...
Old Apr 18, 2005 | 06:58 AM
Default Re: (90ED9)
yay for fix!
you are almost teh win!
b18delturbo
Feb 4, 2006 12:28 AM
gook
30
Sep 29, 2005 10:14 AM
thatbluecrx
Dec 9, 2004 03:28 PM
Knightrider
Aug 8, 2001 01:09 PM
raene
Jul 16, 2001 07:42 PM
