The Most Power Quick
if you get a vtec trans too it is said to have the same numbers as the d16z6 im going to be doing the swap on my friends lx. read this if your interested
https://honda-tech.com/zerothread?id=635580
there time slips too.
yes...they make good stuff.... http://www.deltacam.com You gotta call about honda cams though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">if you get a vtec trans too...[edit]</TD></TR></TABLE>
vtec trans? as in transmission? because vtec has nothing to do with trannys. Maybe you ment the transmissions that they put on the VTEC motors... if so that's also not a good idea because they are either cable b-series or hydro D. There's not D Series cable tranny that came attached to a VTEC motor. Get an Si Cable tranny, although you probably have one if that A6 came with the car or the swap had it on there already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoFast2und »</TD></TR><TR><TD CLASS="quote">yes...they make good stuff.... http://www.deltacam.com You gotta call about honda cams though</TD></TR></TABLE>
anyone make aftermarket d series intake manny/throttle bodies?
that would help those cames make even more of a difference.
I currently have a sohc zc engine i really want a better trottle response and for the car to be a little bit faster but noticeable when you push the gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric16122 »</TD></TR><TR><TD CLASS="quote">what is the best way to bore out a throtle body? can i use my dremel?</TD></TR></TABLE>
Http://www.maxbore.com He works off of honda-tech and has alot of good vouchs. Can't beat good work done cheap. - Darrell
hmmmm...Si tranny + light weight flywheel + methain injection system. About $500 worth of parts and you'll notice it alot. I'll put money on it.
Now if you only do one. Go with the lightened flywheel...less momentus means it moves faster and free'er. Downside is it'll take some getting used to
my crx is an si its a 1990 crx si it has a sohc zc engine also why would i want to sell my fuel rail believe it or not it did make a small difference
